Help, rear diff oil change
Old Apr 7, 2018 | 10:08 AM
Robrote's Avatar
Robrote
Default Help, rear diff oil change
I'm in the middle of changing out the oil in my rear diff. I only got about 1.1 quarts out when i drained it. I have now added 2 quarts and 4 oz of limited slip additive and I'ts still not dripping out of the fill hole. I have the car completely level. I even stuck my pinky in the hole and it came out clean. I'm nervous about putting any more fluid in.
Help! Thanks
2000, A4, 94K miles
Old Apr 7, 2018 | 11:11 AM
pjdbm's Avatar
pjdbm
Thats odd, did this last year, with car absolute level, just under 2 quarts and did not need the limited slip additive with Amsoil synthetic
Old Apr 7, 2018 | 11:21 AM
grantv's Avatar
grantv
Here's a link to a site showing the change process.
http://www.toquez06.com/diff.html
Any chance you made an error?
Old Apr 7, 2018 | 11:31 AM
Robrote's Avatar
Robrote
I actually checked out that webpage. Great page by the way. I ended up putting a full 2 qts in and put the plug back in. I'm hoping for the best.
Old Apr 7, 2018 | 03:48 PM
vettenuts's Avatar
vettenuts
I would be careful with that approach. Mine has always taken just shy of 2 quarts. If yours was low with no signs of leakage and isn't full with the proper amount something is amiss. I would want to understand why before driving it and hoping all is OK. It may be perfectly fine but based on your description something doesn't pass the smell test.
Old Apr 7, 2018 | 03:53 PM
Robrote's Avatar
Robrote
I agree. I buttoned it up for the day, but I'm going to look at it again tomorrow. I'm concerned with the little amount that came out when I drained it.
Old Apr 7, 2018 | 06:25 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i dont see how you can over fill it if the fill plug is horizontal.....and the car is level. fill it until it starts to dribble out.
Old Apr 7, 2018 | 08:12 PM
StingrayRebel's Avatar
StingrayRebel
maybe a longshot and just throwing ideas out there but does your car have an added diff cooler or even a c6 diff swap?... either of those would require more fluid but if everything is bone stock, the car is level, and the fluid isn't immediately leaking out somewhere, I don't see any way it could take over 2qts of fluid and not be leaking out of the fill hole or even able to feel it with your finger through the hole... I would fill it until fluid starts to dribble out of the fill hole regardless of how much you think it should take
Old Apr 8, 2018 | 06:31 PM
02GoldVette's Avatar
02GoldVette
Just did my rear differential today. Took about 1.8 quarts. Just keep pumping the oil in slowly after 1.5 quarts and you'll notice it start to dribble out.
Old Apr 8, 2018 | 06:36 PM
Robrote's Avatar
Robrote
I'm going to get it on a true level surface and check it. My only thought is that it wasn't level when I have it on the stands
Old Apr 8, 2018 | 10:00 PM
grantv's Avatar
grantv
A garage floor is generally not level, so if you went by distance from floor front and back that wouldn't be right. I use a level on the bottom of my car.
That said, I doubt being a bit off would alter the fluid level much.
Old Apr 9, 2018 | 09:03 AM
bravo29's Avatar
bravo29
Exactly what I did. Mine started to dribble out about the 1.7 mark.
To Help, rear diff oil change
