Active Handling Question
Old Apr 10, 2018 | 02:13 PM
AnabolicZod's Avatar
AnabolicZod
Default Active Handling Question
Hi Gang,
I'm pretty familiar with the issue with the active handling/tcs module failing after some time, but my question is this: I've been getting just the Active Handling Error - Service Vehicle soon message only, nothing else. I was under the assumption that if the module were to fail, I would have multiple faults, i.e. active handling/tcs, etc... I read through the stickies and did a search but couldn't find anything relating to just that error, or my searching on here just plain sucks. Any ideas? Thanks in advance.
p.s. Finally was able to get get her out of storage today. What a lousy spring it's been here in Ohio...
Old Apr 10, 2018 | 03:41 PM
JR-01's Avatar
JR-01
http://www.c5forum.com/ayc/dtcdic.php
Pull the codes and post them. It might give you a clue to the problem.
Old Apr 10, 2018 | 03:43 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Pull the code. Probably a 1214. And probably the EBCM module.
Old Apr 10, 2018 | 03:47 PM
AnabolicZod
Thanks, guys. I know I should have posted the code but forgot to pull it. I'll do it tomorrow. Appreciate the help.
Old Apr 10, 2018 | 11:41 PM
Moved to C5 Tech.
Old Apr 11, 2018 | 09:49 AM
AnabolicZod
Thanks, Jack. I probably should have posted this in Tech, my mistake.
I pulled the code: C1288 H. Any suggestions?
Old Apr 11, 2018 | 10:21 AM
JR-01's Avatar
JR-01
Steering Position Sensor Circuit and it's a history code. May be a bad connection or low voltage. Do you have a good battery at 100% charge?
Old Apr 11, 2018 | 10:34 AM
AnabolicZod
I would like to think I have a good charge. Replaced the battery last year before I put her away for winter storage. I also had it on a tender throughout winter. Is it rare for the steering position sensor to go bad?
Old Apr 11, 2018 | 10:38 AM
JR-01's Avatar
JR-01
Sounds like the battery should be good. I have no experience with the sensor. I am sure others that do will chime in.
Old Apr 11, 2018 | 10:49 AM
AnabolicZod
Thanks, JR!
Old Apr 11, 2018 | 11:11 AM
JR-01's Avatar
JR-01
Try clearing the code and see if it comes back.
Old Apr 11, 2018 | 11:36 AM
AnabolicZod
I've cleared it a handful of times - keeps coming back.
Old Apr 11, 2018 | 11:40 AM
JR-01's Avatar
JR-01
Good luck. I hope it's an easy fix.
Old Apr 11, 2018 | 04:52 PM
BigGun's Avatar
BigGun
It is not uncommon for that sensor to fail. Unlike earlier years the sensor for your 03 is sill available. Check the connections, you will need to disconnect the steering column to replace the sensor.
Old Apr 11, 2018 | 08:03 PM
coia96vette's Avatar
coia96vette
Yep that is the swps going out. Happened to my '04. The part number is 88965543 and they cost about $70. You can change it yourself or take it to a real corvette mechanic. Takes about 2.5 to 3 hours to replace.
Old Apr 11, 2018 | 08:12 PM
sloopdawg's Avatar
sloopdawg
I get the message from time to time, but I've got a ignition switch issue. If I let the car sit for a while (week or two) before starting it I'll get the code. The way I understand it is if the computer dosen't get the proper voltage it throws a code. if I drive it every day I don't usually get it. I just reset it and keep on keepin' on. May not be your issue but food for thought.
Old Apr 12, 2018 | 10:06 AM
Gordy M's Avatar
Gordy M
Years ago this happened a few times on cars that were not driven very much, after a long cold winter it would appear. The solution at that time was replace the SWPS or what a few did was raise the front of the car a few inches off the ground, turn the wheels lock to lock about 100+ times, turn the engine off and clear the codes. On restart and there after the code went away. If the SWPS is the problem the code will reappear.
To Active Handling Question
