service steerin column lock
Old Apr 12, 2018 | 09:15 PM
rubyvett's Avatar
rubyvett
5th Gear
Default service steerin column lock
after starting 04 6sp for first time this season with dead battery after charging battery dash reads service column lock if after I start vette & hit reset on dash it fine until next time I restart again it starts & goes every time Ihad the recall for that done 5 yrs ago when I would not let you drive more than a few feet have not had problem since it starts &runs every time now except for reading on dash
Old Apr 13, 2018 | 08:10 AM
runner140*'s Avatar
runner140*
Dear ruby, you, being a member on the Forum since 2013, we have covered this a few THOUSAND times. Either do a Forum search or do a Google search. LMC5 may be in your future.
Old Apr 13, 2018 | 10:37 AM
Dbl_D718's Avatar
Dbl_D718
You probably need a new battery, first. Your battery may still be strong enough to start the car, but it's weaker now and is causing the column lock issue. Monitor your battery voltage, I bet it drops well below 12 volts as you start the car.
I'm in the same boat right now and have a battery on order. I also recommend the LCM5, though.
To service steerin column lock
