Engine movement
Old Apr 13, 2018 | 01:34 PM
ADTvette's Avatar
ADTvette
Default Engine movement
When I’m sitting at a red light, I can feel the car rockin’ back and forth. When I raise the hood, I see the beltt spinning and the engine rockin’ back and forth. Is this normal? I have a ‘97 automatic. I know it”s a big engine. It’s not a huge rockin’ motion but noticeable.
Old Apr 13, 2018 | 01:58 PM
runner140*'s Avatar
runner140*
With the engine running, open the hood, on the passenger side, look at your "harmonic balancer"....outside of spinning, should not be moving (much). If it is doing a wobble, you have a problem.
Old Apr 13, 2018 | 02:10 PM
ADTvette's Avatar
ADTvette
What does the harmonic balancer look like?
Old Apr 13, 2018 | 03:27 PM
Smoken1's Avatar
Smoken1
The lower one in this picture
Old Apr 13, 2018 | 04:13 PM
StingrayRebel's Avatar
StingrayRebel
yes it's very common... the stock mounts don't do a very good job of keeping the engine stable which also contributes to wheelhop... put in a good set of aftermarket mounts and that will keep the engine solid
Old Apr 13, 2018 | 04:16 PM
ADTvette's Avatar
ADTvette
Thank you everyone for your help. I will take a look the next time I drive. I don’t remember seing any movement from the part indicated. Thanks again
Old Apr 13, 2018 | 07:34 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
I replaced mine with Hinson engine (and transmission) mounts and now very steady.
Old Apr 13, 2018 | 07:40 PM
Spaceme1117's Avatar
Spaceme1117
A little bit of rocking of the engine is normal. If it is really moving a lot, the engine mounts may be bad.
Considering that your car is now 20+ years old. It may be time for a new set of mounts.
I would just stick with stock mounts. Aftermarket mounts tend to be much stiffer and will transmit more vibration to the cab and to you.
Old Apr 13, 2018 | 09:11 PM
StingrayRebel
my pfadt engine mounts didn't make any more noise than stock and are still doing their job after the past 7 years or so... I ran pfadt's diff mount as well and had the same results, I only removed it because I swapped in a c6 drivetrain and it wouldn't work anymore
To Engine movement
