Car dies when engine is warm
Old Apr 17, 2018 | 04:01 PM
Wanda300's Avatar
Wanda300
3rd Gear
Default Car dies when engine is warm
After engine is warm, Car will die when clutch is engaged while waiting in traffic or coming to a stop after driving for a period of time. 2003 Z06 50th anniversary. Less than 20,000 miles. Need Help, No one can find problem.
Old Apr 17, 2018 | 06:25 PM
SilverC54me's Avatar
SilverC54me
Do you loose power to everything or does the motor just cut out?
Gary
Old Apr 22, 2018 | 03:37 AM
Wanda300's Avatar
Wanda300
3rd Gear
Gary
Motor would cut off. After being showed how to pull codes. Mechanic found the O2 sensors was malfunctioning. ThankYou
Old Apr 22, 2018 | 03:41 AM
Wanda300's Avatar
Wanda300
3rd Gear
Originally Posted by 8VETTE7
Pull and post all your codes. If you have never pulled codes on a C5 here is how:
https://youtu.be/SviRjIsy9G4
List the codes under the sensor that they show up with. ie 10 - PCM or 28 - TCS or 40 - BCM ..... etc ..... Include the H or C or HC that follow the 5 character code.
If any sensor has NO COMM next to it post that also.
Even better would be to pull the codes the next time this happens BEFORE you turn the key to the OFF position. To pull codes with the engine running or before you turn the key OFF then back to the ON position you need to use the RESET button on the right side of the dash to clear any messages displayed in the Driver Information Center (DIC) and then pull codes as normal. There might be some codes with the letter C after them that could disappear if the key were cycled to OFF then ON again to pull the codes.
Thank you for the video. It helped mechanic with codes, It was the O2 sensors malfunctioning due to the wires being spliced at a performance shop. Thank you again for your help. Wanda
To Car dies when engine is warm
