2001 z06 speedometer
Old Apr 18, 2018 | 05:01 PM
turkey's Avatar
turkey
3rd Gear
Default 2001 z06 speedometer
My 2001 z06 speedometer is stuck on km, the controls on the right hand side won't respond. Any suggestions?
Old Apr 18, 2018 | 06:41 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Is it working when you set it to MPH ?? Either way these early C5's are known to have many electrical gremlins----On my 02 I just lived with them---It may cost $1000's to fix and diagnose---Often times it's just the dash cluster that has a short or has failed
If you are not getting either a MPH or KM reading then look at your "speedo sensor located on your trans or rear dif
Old Apr 18, 2018 | 10:17 PM
RedRiderZR1's Avatar
RedRiderZR1
I had the same issue. Had to replace the cluster. It would change back to MPH once in a while. Then it would not change back no matter how many times I tried.
To 2001 z06 speedometer
