AC Compressor replacement
Old Apr 21, 2018 | 10:00 AM
billy mild's Avatar
billy mild
Default AC Compressor replacement
https://www.corvetteforum.com/forums...-a-2000-a.html
I saw this thread searching for AC Compressor information. I would like to know if people have used the 4 seasons AC Compressor in the past. I would prefer a AC/Delco compressor, but I'm looking to do this on a budget if possible. I have never replaced an AC Compressor before.
What is the best way to tackle this job? Can I rent all the tools needed from auto parts store?
Old Apr 21, 2018 | 10:46 AM
Trkdrvr's Avatar
Trkdrvr
Just had a complete rebuild of my A/C system done,at a local shop.along with new vent actuators. Total cost was $3,800.freeze my butt in there now.
Old Apr 21, 2018 | 02:14 PM
Carl Timonen's Avatar
Carl Timonen
Last year, I had a shop install compressor, accumulator and orifice. Total was about $800. They said the condenser was in good shape, so saved about $100.
Old Apr 21, 2018 | 02:20 PM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
$3800 that seems very pricey
Old Apr 21, 2018 | 02:34 PM
1999corvettels1's Avatar
1999corvettels1
I have replaced compressor on brother's Neon, and one on my mom's Grand Am.
Both I got brand new compressors made by 4 seasons, cost a little more but only want to do once.
I would think C5 would be easier to get compressor in and out, those FWD cars are tight and compressors were hardest getting out and in between engine and frame/unibody.
You can rent a vacuum pump at autozone loan a tool.
I bought myself automotive professional type gauges, already had a jug of R134-A, and a refrigerant scale from being in HVAC and refrigeration business.
Also you want to replace drier, and parts store might make you buy a new metering device to get max warranty, 3 years on the ones I put in.
Not sure if they rent refrigerant scale and good gauges.
Maybe you could put the parts on and pay a shop to evacuate and charge with R134-A?
If so, that drier needs to be put in right before vacuum pump starts pulling down a vacuum, the desiccant will start absorbing moisture from the air.
So timing that right could be tricky.
When I do mine I have my gauges and vacuum pump already set up to go and as soon as drier is in, start evacuating.
Old Apr 21, 2018 | 02:45 PM
1999corvettels1
My friend who is also a A/C guy on houses, payed Big O tires to recharge his A/C in his 2005 Chevy Express van, he knows nothing about cars.
They charged a flat rate of I think 130.00 to evacuate and weigh in a full charge.
Just for a reference, summer 2017.
For 130.00 that's not that bad, refrigerant included.
Old Apr 21, 2018 | 02:51 PM
1999corvettels1
I almost forgot, you will have to pour oil out of old compressor into a bowl or something, find a way to measure it.
Then add that much new oil to new compressor into the suction port, then slowly rotate the hub a few times to draw the oil into the compressor.
There will be a instruction card telling how to do this, the compressor may or may not come with a container of refrigerant oil.
If it doesn't come with oil, buy exact type the card/instructions tell you.
Old Apr 21, 2018 | 03:01 PM
1999corvettels1
What failed with compressor?
Knocking or locked up?
Are you sure it's not just kicking on because it has low charge?
There is a switch I call low cutout switch, forget what Automotive A/C people call it, trinary switch?, also cuts off compressor when high head pressure.
The Neon clutch coil failed and a new clutch was almost as much as a whole compressor including clutch and hub, plus I had no room to replace clutch coil while on car so I said time for new compressor.
The grand am compressor locked up, when you turned on ac the engine would die.
Old Apr 21, 2018 | 04:25 PM
Vanover's Avatar
Vanover
Old Apr 21, 2018 | 04:41 PM
billy mild's Avatar
billy mild
I had a shop actually look at it. He quoted me $1000 to swap it out with a brand new AC Delco unit.
He tried to recharge it twice, and he noticed a little knocking when it was trying to run.b
Old Apr 21, 2018 | 05:00 PM
1999corvettels1
Does the a/c work?
This may be bad advice but if it blows cold and has a minor knocking sound, I might just see what happens.
Could you video the noise?
Old Apr 21, 2018 | 10:04 PM
Moved to C5 Tech.
Old Apr 21, 2018 | 11:37 PM
Frank4202's Avatar
Frank4202
I bought my 4 seasons compressor from rock auto. Had it a year now and no problems so far. Has the same warranty as the Ac Delco.
Old Apr 22, 2018 | 01:18 PM
zone-7's Avatar
zone-7
I did the AC compressor and component renewal when I did the heads and cam (myself). Also, did the motor mounts (while I'm in there)
It's was much easier with major components out of the way. I can see how labor costs can escalate on a job like this.
To AC Compressor replacement
