How much $ for gears/install
Old Oct 17, 2002 | 12:52 AM
scottsvette's Avatar
scottsvette
Cruising
Default How much $ for gears/install
How much are you guys paying for 3.42 gears and labor to intall them? I have a 99 A4 with 3.15s and want 3.42s. I called West Coast Corvettes in Orange County, CA today. They want $895 for the 3.42s (exchange),
$600 to install the gears AND $500 for a new computer, they require it, AND $100 to program the new computer. They claim the Hypertech programmer does not provide enough adjustment to correct the speedometer. These prices seem high. Then I asked them how much LABOR ONLY to change a cam and valve springs...$3300.00!!!
Can anyone recommend a cheaper source for gears, such as take offs, or a place in So Cal to install them? Will the Hypertech fully correct the speedo or not? Thanks.
Old Oct 17, 2002 | 03:03 AM
SFVetteman's Avatar
SFVetteman
Default Re: How much $ for gears/install (scottsvette)
I'd buy the 3.42's through the C5 Parts For Sale right here on the forum. You could then sell your 3.15's and reduce your cost for the gears by quite a bit.
For installation, talk to Andy Green of A&A Corvette Specialties. He's located in Port Hueneme near Oxnard. You can email him at Andy@AandAcorvette.com or phone him at 805.658.8299
The Hypertech has problems programing for 3.42's for A4s. The new Diablo Predetor can do it: http://forums.corvetteforum.com/zerothread?id=386879 and LS1edit can also. You don't need a new computer.
Old Oct 17, 2002 | 03:05 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
WCC is really getting high on their prices, they charged me $487 the first time and & $725 the second time for a converter and gear change (because I didn't purchase any parts from them on the second change).
You will need someone to reprogram your computer, the HPP will not do it. [b]What do you mean, you need a new computer they require it?? I have the same computer and it has been reprogrammed several times. In fact, I told WCC all I wanted was the ST-3500 installed with the 3.73's, no problem and no computer work. I got Steve Cole at TTS to reprogram my computer.
I had Mike (I think thats his name), at Andy's Auto in Monrovia (626)447-3707 install my cam and valve train package for $450, he does great work. He might install gears, but you will still need to have your computer reprogrammed for cam change and again for a gear change. Reprogramming is not cheap!
Click on my Per Mods! It my help, good Luck.
Old Oct 17, 2002 | 03:44 AM
Barely Legal's Avatar
Barely Legal
Default Re: How much $ for gears/install (wallstAL)
The HPP3 will adjust for gears just fine. Been then, done that. I say go elsewhere.
Old Oct 17, 2002 | 03:59 AM
NYtoCA's Avatar
NYtoCA
Default Re: How much $ for gears/install (Barely Legal)
Andy quoted me a VERY reasonable price! Call him!
Old Oct 17, 2002 | 03:26 PM
SFVetteman's Avatar
SFVetteman
From comments I've seen on the forum, it seems to be a hit and miss proposition with A4's. Some people have had success while many have not.
Old Oct 17, 2002 | 03:55 PM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: How much $ for gears/install (SFVetteman)
That price is wayyyyy high :yesnod:
Old Oct 17, 2002 | 04:09 PM
Untouchable00's Avatar
Untouchable00
Go elsewhere, that is a joke...
Old Oct 17, 2002 | 04:23 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Default Re: How much $ for gears/install (Untouchable00)
The price seems high but the 500$ is probably for the LS1 Edit and not for a new comp, or they swap it out with one pre-programmed for the new gears and you are paying for the license (LS1)
BTW you can go used on the gears save a couple hundy and retain the stock set or sell em..... or even cheaper yet would be to buy the ring and pinion and use your case.
[Modified by sweetcharity, 3:25 PM 10/17/2002]
Old Oct 18, 2002 | 11:19 AM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Default Re: How much $ for gears/install (sweetcharity)
Just for reference we get $350. for this install but we're on the east coast. The 3.42 differential is $849.99 outright (no core needed). Andy at A&A seems to be very popular for installations for the guys in CA.
Tom
Old Oct 18, 2002 | 12:00 PM
Fahtrim's Avatar
Fahtrim
Default Re: How much $ for gears/install (tbyrne)
I give props to Andy for the CA installs.
Old Oct 18, 2002 | 12:12 PM
4THTOY's Avatar
4THTOY
I'll sell you a set of 342's cheap, Andy just took them out of my car, and he can do your install for a very reasonable cost, + he's a great guy
To How much $ for gears/install
