Belt-Harmonic Balancer
Old Apr 26, 2018 | 09:35 PM
MightyMike's Avatar
MightyMike
Default Belt-Harmonic Balancer
Hey Guys,
I'm doing some spring time maintenance on the C5. I took a video of a cold start. It looks like my belt turns a little and I see a little wobble on the Balancer. I was hoping that someone with some experience can tell me what they think by watching the attached video. The squeaking goes away after 5 minutes.
Thanks in advance,
Mike
PS 2000 C5 FRC
Old Apr 26, 2018 | 11:51 PM
pjdbm's Avatar
pjdbm
I watched the whole thing and it does not look bad at all, mine was much worse
I did have the same belt squeal before I replaced the HB and I replaced all pulleys and tenioners along with a Gator belt, no more belt squeals.
Old Apr 27, 2018 | 12:02 AM
foggy's Avatar
foggy
Replace the tensioner assembly and belt. You should be OK.. I don't see any
kind of wobble to be of concern
Old Apr 27, 2018 | 07:55 AM
vettenuts's Avatar
vettenuts
Just make sure to buy a good quality belt. I agree, I don't see a concern with the HB.
Old Apr 27, 2018 | 08:25 AM
MightyMike's Avatar
MightyMike
Thanks for the replies!!!! I'll start with a new tensioner and belt.
Old Apr 27, 2018 | 04:31 PM
tupeloC5's Avatar
tupeloC5
I just posted this in another thread in the C5 General forum but...
Paint a white stripe from the inner hub, across the rubber and onto the outer ring. If the outer hub starts moving around as the balancer wears out, you'll be able to see it in the fact that your marks no longer line up.
To Belt-Harmonic Balancer
