car quitting.
Old Apr 28, 2018 | 05:08 PM
Gregg_Leblanc's Avatar
Gregg_Leblanc
1st Gear
Default car quitting.
My 1999 c5 corvette 5.7 litre engine will almost start and then just quits before it'll start.I had it in storage for the winter months. It worked good when I put it in storage. I checked all of the fuses and they are all ok.
Old Apr 28, 2018 | 06:38 PM
JR-01's Avatar
JR-01
Is your battery 100% charged and in good condition?
Old Apr 28, 2018 | 11:40 PM
Moved to C5 Tech.
Old Apr 29, 2018 | 10:41 AM
mikesvette1's Avatar
mikesvette1
my 2001 did the same thing but sometimes it would start and run fine. At first didn't get any codes so I changed my battery and it still would do it sometimes. I cleaned the pellets on both of my keys and then it threw a code. I don"t remember the code right now but it did refer to the VATS system. I measured my resistance on my keys and ordered a GM resistor kit online. After I pulled the center console, the key cylinder has a wire coming off of it and I traced it back to where it plugs into the VATs system, just under the dash, put the resistor and and car has failed to start in 3 months. Radio shack has some resistors and I soldered all connections and put it back together. This is what happened to mine, hope this helps.
Old Apr 29, 2018 | 10:46 AM
mikesvette1
the code i received was B2723, pass key detection circuit, BCM MODULE theft deterrent.
Old Apr 29, 2018 | 11:59 AM
mikesvette1
OK sorry that was what was happening to mine, just trying to help.
Old Apr 29, 2018 | 12:03 PM
mikesvette1
Thanks for the information and knowledge, The forum and you have helped in so many ways, thanks.
To car quitting.
