Will not turn over
Old May 3, 2018 | 05:47 PM
Vetteman 25's Avatar
Vetteman 25
1st Gear
Default Will not turn over
Car started and ran good went for a short ride came home turn off car let it out for a little while then went to put it back in storage turn key and it was dead put on jumper still dead dash lights are on but won’t turn over starter is just 1year old don’t know what it could be thanks for any help Richard
Old May 3, 2018 | 06:20 PM
glbeauchamp's Avatar
glbeauchamp
Check the battery posts first off for losseness.
Old May 3, 2018 | 06:23 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Did your dome lights dim when you tried to turn it over ??...if NO dimming of dome light you are not getting current to starter. you'd have to check from starter back...power to starter control wire while cranking??...I'd do a voltage drop check on both battery cables and from battery post to the cables too !!...best bet is to get a wiring diagram and if you don't have one you can get one from bbbind.com ...could be ignition switch, starter or theft deterrent relay,neutral safety or park neutral safety switch...you just have to do a logical systematic approach to troubleshooting !!
Old May 3, 2018 | 06:59 PM
3sACROWD's Avatar
3sACROWD
Start with getting the battery load tested. Sounds like you have a bad cell. If you hook it up to a regular charger it will show low and 10 minutes later show full charge. That would also indicate a bad cell.
Old May 12, 2025 | 07:08 PM
Scbdude's Avatar
Scbdude
2nd Gear
Default C6 no crank no start
Why are there no solutions posted for the same exact problem on several threads. Has nobody ever found a solution for this?
Old May 12, 2025 | 07:49 PM
redzg's Avatar
redzg
I’ve had the same situation, found the probable cause here using a search — battery cables less than sufficiently tight — implemented correction and recorded my results. Others have had it be the connections at the starter. Same symptom, similar cause, different location on the car.
To Will not turn over
