Clutch "while I'm there"
Old May 8, 2025 | 12:16 PM
Snaps's Avatar
Snaps
Default Clutch "while I'm there"
Will be swapping the clutch out in my 2004 to support my new supercharger HP. Was wondering what items I should also change while I have the driveline out? Besides slave and torque tube bushings.
Popular Reply
May 8, 2025, 01:12 PM
MetalMan2's Avatar
MetalMan2
Some things you might consider, all of which I did "while I was in there" 5 years ago:
  • clutch kit, pilot bearing
  • rear main seal, used the latest version with the full cover and includes screws with larger heads (my old RMS was not leaking)
  • billet oil barbell (i.e. from Sac City) if the rear cover is off anyways
  • slave cylinder
  • remote clutch bleeder
  • torque tube bearings and couplers
  • thicker and insulated tunnel plate (already had this, but you take it off so putting on a new one during reinstall can make sense)
  • tunnel insulation, DEI makes a kit
  • replace clutch packs in diff's LSD with pieces from C6 Z06. My C5Z's clutch packs and belleville washers/springs were TOAST with 70k miles. Most C5s have broken bellevilles and therefore no real LSD action (diff becomes open)
  • diff axle seals, diff-to-trans seal, diff side cover seals (especially if replacing clutch packs)
  • some people will upgrade some of the diff internals (beyond LSD) to C6 Z06, but I opted not to with stock LS6 power
  • any hard shifting in the trans, you might consider rebuilding the trans. I DIY-rebuilt mine, this was the main reason for taking everything apart. Reverse was really hard to get. If you're interested I had a whole saga and ended up 'improving/fixing' reverse while rebuilding the trans.
  • perfect time to upgrade the shifter linkage to eliminate slop. My shifter is 98% slop-free because of linkage upgrade, TMOD lower box, and Hurst shifter. TMOD is one source for shifter linkage upgrade.
I document everything religiously and can provide any P/Ns I used that you're interested in.
Old May 8, 2025 | 01:12 PM
MetalMan2's Avatar
MetalMan2
  • slave cylinder
Old May 9, 2025 | 12:59 AM
lespaulr0cker's Avatar
lespaulr0cker
Torque tube bearings
Old May 9, 2025 | 02:17 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Trevor's list is spot on.
I would specify to also consider the C&S Corvtte (corvettepartscenter.com) upgraded rear engine plate which comes with a rear main seal. It is a redesign which will help to prevent future oil leaks.
Adj master cyl
Old May 9, 2025 | 12:10 PM
TMODcustoms's Avatar
0TMODcustoms
Former Vendor
, spot on. I cry a little every time I see a sloppy old linkage go back into a car. If you want to tighten up, smooth out your / any shifter the linkage upgrade is great. You have to send your linkage in to be upgraded, I usually have them back in the mail within a day or two.
Old May 10, 2025 | 12:13 AM
vette4fl's Avatar
vette4fl
Absolutely have TMOD do the linkage and the lower shifter box. That’s money in the bank.
Old May 10, 2025 | 02:42 PM
hyperv6's Avatar
hyperv6
Now is the time to address it all. Not cheap but less expensive than doing it later again.
People often save money on parts but get hammered later when things break.
Old May 11, 2025 | 09:50 PM
Mc556's Avatar
Mc556
  • slave cylinder
The above may sound crazy, but it’s some solid advice if your committed to the car.
If not then I’d at least put new torque tube couplings on. If you’re doing your own work where labor isn’t crushing you then I wouldn’t skip any of it.
Old May 12, 2025 | 10:34 PM
Moved to C5 Tech.
To Clutch "while I'm there"
