HVAC Issues
Old May 4, 2018 | 05:13 PM
dslmagic's Avatar
dslmagic
Default HVAC Issues
Can ANYBODY tell me where the blend door for the a/c is located? I have air flow from my vents, the defrost vent and the floor vents all at the same time and I think the blend door is the issue. O ly I can't find it. Please help and thanks in advance
Old May 4, 2018 | 05:47 PM
Dark Sarcasm's Avatar
Dark Sarcasm
Search HVAC issues and you'll have a lot of reading to do. Have you checked for any HVAC codes in the DIC? It's a good place to start.
This thread might help give you visuals for what you're looking at under the dash.
https://www.corvetteforum.com/forums...placement.html
Old May 4, 2018 | 06:40 PM
dslmagic's Avatar
dslmagic
I don't have any HVAC codes. The heat and a/c both work and I have control over all functions, but as I said earlier the air flows out of all vents at the same time. This leads me to think that the blend door or whatever controls what vents I get air flow out is the problem. I have heat or a/c and the windows don't fog up. But airflow is definitely out of all locations.
Old May 4, 2018 | 07:10 PM
Moved to C5 Tech.
Old May 4, 2018 | 07:21 PM
RedRiderZR1's Avatar
RedRiderZR1
Those actuators are vacuum operated. Take a look at this link. Test the vacuum.
https://www.corvetteforum.com/forums...with-pics.html
Old May 4, 2018 | 07:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have a vacuum supply issue!!!!!!!
Bill
To HVAC Issues
