A/C Actuator Replacement
Old May 18, 2010 | 12:53 PM
Quick 8's Avatar
Quick 8
Default A/C Actuator Replacement
Hello,
I need to replace the passenger side A/C Actuator, but I don't know where it is or how to remove it. Is there a thread that anyone knows about that describes the procedure? I have been searching for it for several hours now, but I can not find anything.
Your help is greatly appreciated.
Thank you.
Best Regards,
Jim
Old May 18, 2010 | 01:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ACTUATOR??? Do you mean the blend door electric servo or an actual vacuum actuator??
BC
Old May 18, 2010 | 01:26 PM
Quick 8's Avatar
Quick 8
The blend door servo. I've tried everthing else I can find, and now that is the last thing left. When the A/C is on, heat comes out of the passenger side vents. As far as I can tell, all of the vacuum hoses are ok. I've tried clearing the codes, pulling the fuses, resetting the system, and nothing has helped.
Old May 18, 2010 | 03:49 PM
egrand333's Avatar
egrand333
Had the exact problem with my '97 about a month ago. All codes pointed to passenger side temp actuator (forgot the codes) I tried all the stuff you did and nothing helped. Lots of threads on this topic. It seemed to be a bit more work than I wanted to try on my own so took it to dealer. Actuator $263 (could be bought online for $150), labor $420, total around $700! Ouch! Some people on this forum say its not that hard to do, others say its a nightmare. Do a search and you decide. Good Luck!
Old May 18, 2010 | 04:12 PM
Quick 8's Avatar
Quick 8
Mine is on a 2002 with the dual zone climate control. I already bought the actuator, and would like to do it myself.
I have searched for over a couple hours though and can't find any info on how to actually do it. I would even settle for somebody just telling me where it is located. Nothing so far though.
Old May 18, 2010 | 05:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well it looks like this:
Hope that helps.
BC
Old May 18, 2010 | 06:02 PM
egrand333's Avatar
egrand333
There are detailed instructions with pics out there. I wish I could be of more help in directing you were to look but I am still not as familliar with this sight as I hope to be someday. Someone will eventually point you in the right direction. I do remember the actuator being up under the dash somewere and that you have to remove a portion of the dash to get to it. From what I remember reading about it, it didn't sound like fun unless you like unless you like being in tight, cramped positions for long periods of time. In fact the last post I remember reading about it the guy and his "mechanic" friend replaced the actuator themselves, then after putting everything back together discovered all kinds of electrical gremlins and other problems that weren't there before and ended up taking it to the dealer anyway. I understand the drivers side one is not as hard to replace. I see Mr. Curlee posted before mine went out. Now if you can be shown how to get to it while its still in the car!
Old May 18, 2010 | 06:19 PM
egrand333's Avatar
egrand333
It is my understanding that the "newer" actuators don't come put together with screws anymore like the one shown in BC's pics. You may want to check the one you bought. (not sure if the screwless one is "new and improved") I looked at the one they put in my car and it was screwless.
Old May 18, 2010 | 06:35 PM
Quick 8's Avatar
Quick 8
Thanks a lot for the replies. Bill, in the first picture, I see that the actuators/servos are attached to the sides of the section with the foam seals. Can you tell me where the section with the foam seals is located? Is that section centered in the car?
Also, am I looking at the unit from the front or the back of the car?
Thanks a lot for the help
-Jim
Old May 18, 2010 | 07:05 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres a picture of a C6 unit installed in the dash fr reference:
C5 unit in dash:
C5 acutators outlined in RED:
BC
Old May 18, 2010 | 07:52 PM
Quick 8's Avatar
Quick 8
Thanks. That REALLY helps a LOT! Now I get it. It looks like I'll need to remove the whole dash pad. I assume the access is too tight to get at it from below.
Does this sound right?
Thanks again...
-Jim
Old May 18, 2010 | 08:04 PM
Quick 8's Avatar
Quick 8
Assuming I need to remove the dash pad, can I follow the procedure listed in post #48 of this link?
http://forums.corvetteforum.com/c5-t...th-pics-3.html
If so, I'll do it, but it looks pretty ugly!
Thanks,
-Jim
Old May 19, 2010 | 03:14 PM
Quick 8's Avatar
Quick 8
FYI- Its done. The problem was the actuator. After I got it back together, it was like a meat locker in the car. I had to turn the A/C down pretty quickly. It works great.
Here are some notes for the anyone trying this in the future:
You MUST follow the instructions in this thread:
Go to post #48. Then, follow the directions for dash removal, starting with the center console, trim panels, dash, glove box, etc. When you get to the point in post #48 where the picture showing the dash, etc. is on the ground in his garage, you can stop following the post.
Then, find the large aluminum bracket that is above where the glovebox was. It supports the air bag. Make a note of where the bolts are that hold it into place. Maybe trace the outline of it. Then unbolt it, and slide it out to the side, rotating the left side of the backet toward the passenger's side door. You will now have access to the actuator to replace it. You can unbolt it without moving the bracket mentioned above, but there is no room to get it out for replacement.
After replacing the actuator, put everything back in the reverse order. Be sure that the aluminum bracket is as close to the original position as possible. That way, the air bag will line up with the hole in the dash. I would recommend that you NOT put the glove bax back in until you are sure that the airbag lines up with the hole in the dash. If it does not, then loosen the four nuts up under the aluminum bracket. These hold the air bag in place. You can then fine tune the fit to make it match the dash exactly.
I hope these notes help someone in the future.
Thanks for your help guys.
-Jim
Old May 19, 2010 | 03:15 PM
Quick 8's Avatar
Quick 8
Oh, by the way, it took about 3-1/2 hours total to do the job.
Hope this helps.
-Jim
Old May 19, 2010 | 03:36 PM
egrand333's Avatar
egrand333
Yes it helps! Helps me feel like a fool for not trying to do it myself. Honestly, some people are just more confident than others when it comes to doing a job like you just did. It just looked to complicated to me although I would not hesitate to remove the intake myself to replace the oil pressure sending unit and check valve when the time comes. Congratulations on a job well done!
Old Jul 21, 2011 | 04:07 PM
Jetts4u2's Avatar
Jetts4u2
Based on this thread, I am replacing mine right now!! Tested it and it works great! It never worked on the passenger side for 6 years of ownership. Quotes of $900 kept me from doing it. VetteNutts sent me a pair of Actuators at a good price and it worked great. I opened my passenger sensor and it had a cracked gear, causing misalignment and losing the home position. Awesome thread, and you guys didn't miss anything, except being carefull with the airbag and disco the battery for safety. Doesn't seam to want to turn the temp down with the passenger control, but good enough. I'll find out from her if it don't work, lol.. I have the dash out and watch the actuators move, cool stuff. Also scanned the code and it cleared.
Old Sep 19, 2017 | 12:16 PM
gwalt584's Avatar
gwalt584
Default air temperature sensor tube
I replaced my actuators this past weekend. My passenger side was not working and it was the classic problem of the broken gear. so I went ahead and replaced both sides.
Actually, not as bad a job as I thought it would be.
My question is related to the Air Temperature sensor tube that goes from the dash, just to the left of the ignition switch, to inside the dash.
you see it in the middle of the picture. is it supposed to be connected to the other tube in the picture?
To A/C Actuator Replacement
Old Sep 19, 2017 | 03:22 PM
Carl Timonen's Avatar
Carl Timonen
Unless I'm mistaken (which could be the case) there is a small muffler that goes there.
It's a split plastic piece that holds a small piece of foam.
Old Sep 19, 2017 | 04:24 PM
gwalt584's Avatar
gwalt584
Default foam
I guess the next question is where do you find one and is it necessary enough to have to take the dash out again?
Old Sep 19, 2017 | 07:07 PM
Carl Timonen
Personally I would just find something to bridge the gap. No, you don't need to remove the dash. I was able to access from the driver's foot well.
