defective outside air sensor
Old May 9, 2018 | 03:48 PM
bc6152's Avatar
bc6152
Default defective outside air sensor
I have a '98 with NO codes posted. Warm air although the outside air temp shows 54F. A/C button flashes but does not stay lit. Today it is 80F here in PA. Took the car out up to 50 mph and the outside air temp went up to 62. A/C button still only flashes. Set to auto mode and 73F.
The mode button changes airflow correctly. The system was recharged last July when I bought the car. Should the ambient outside temp reflect the actual outside temp? IOW should it show somewhere around 80F? Does the 62F reading by the sensor indicate a defective sensor?
If the reading is 62F shouldn't the A/C engage anyway? (above 40F). My understanding is that if the compressor is defective the button will flash and no A/C. Also, if the system requires recharging the same thing will happen - flashing button.
I read about 50 posts after searching from 2007 on up to 2012 and some similar some different. The car has 19k on the clock...
TIA to all...
Old May 9, 2018 | 04:29 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
you can try to unplug it, clean the connection and plug it back in that may work or there is a reset procedure to get the display to read correctly which you can also try
When the Front Defrost, Rear Defog and fan up buttons are pressed simultaneously.
Updates temperature display instantly.
Old May 9, 2018 | 04:34 PM
bc6152's Avatar
bc6152
If the outside air sensor is sending 62F. shouldn't the A/C button stay on, compressor engage, and cool the car?
Old May 9, 2018 | 05:09 PM
BRAVO1's Avatar
BRAVO1
VETERAN
i removed my sensor to check the contacts had rusted away. Order new sensor and connector that will fix the problem.
Old May 9, 2018 | 09:08 PM
jrp1588's Avatar
jrp1588
My air temp sensor was actually plugged up to my under hood light when I bought it. They share the same connector type, and are in about the same area. Genius move on the previous owner's part. haha
Old May 9, 2018 | 09:27 PM
redzg's Avatar
redzg
Mine didn't have a sensor, so the sensor connector was plugged into the hood lamp harness. Definitely brilliant.
Old May 10, 2018 | 10:33 AM
bc6152's Avatar
bc6152
To those of you that have actually replaced the air sensor, what is the easiest way for access? Under the car or under the hood?
TIA...
Old May 10, 2018 | 10:50 AM
jrp1588's Avatar
jrp1588
I just reached right down and had easy access, but I've got a K&N air filter that takes up a lot less space than the stock setup. Not sure what access would be like stock.
Old May 10, 2018 | 12:06 PM
redzg's Avatar
redzg
My cable and connector were in plain sight -- connected incorrectly, as noted above, but easy to reach from under the hood, on the R/H side of the radiator.
Old May 10, 2018 | 03:01 PM
bc6152's Avatar
bc6152
Just to be clear, for R/H side of radiator you mean driver's side standing in front of the car...
Thanks for the info, really appreciated...
Old May 10, 2018 | 03:03 PM
jrp1588's Avatar
jrp1588
It's on the passenger side actually.
Old May 10, 2018 | 06:55 PM
pewter99's Avatar
pewter99
I suppose but its still way off from the actual temp
any updates??
pewter99's Avatar
pewter99
Old May 10, 2018 | 08:06 PM
bc6152's Avatar
bc6152
any updates??
I just got the part late today. Gotta cut an acre of grass, trim, etc.
Updates asap...
Old May 12, 2018 | 03:37 PM
bc6152's Avatar
bc6152
Updates asap...
Replaced the sensor today with an AC Delco new sensor. The connector was very clean and not corroded. The outside temp reading was 54F. when I started the car and never changed. Took the car out up to 50 mph and the display remained at 54F. Pressing the A/C button gets 3-4 flashes and off. No cold air at all. Tried pressing the front defrost, rear defrost, and fan up simultaneously and no change in the outside temp display, still reads 54F. NO CODES SET...
To defective outside air sensor
