EGR - driver side head bolt?
Old May 17, 2018 | 04:46 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default EGR - driver side head bolt?
Long shot here, but does anyone have a picture showing the location of the bolt holding the EGR piping in place behind the driver side head?
I don't feel like pulling the intake right now, so I wanted to see if I could concoct a tool rig to get that pipe off for good.
No codes thrown despite yanking the entire system aside from that pipe. At the moment, I don't remember how I got it to ignore that fact. Probably Tech2.
Old May 17, 2018 | 05:25 PM
Tusc's Avatar
Tusc
I also refer to my Polaner All Fruit Preserves as jelly. But I'm pretty sure you knew I meant the A.I.R. system.
Trying to ditch that junk.
Old May 17, 2018 | 07:17 PM
Smoken1's Avatar
Smoken1
You gotta pull the intake manifold. I Just did all this
Old May 17, 2018 | 10:26 PM
Moved to C5 Tech.
Old May 17, 2018 | 11:30 PM
StingrayRebel's Avatar
StingrayRebel
with the intake on I could get a short wrench on it but could not get enough leverage to break it loose... I believe it is a 15mm and for whatever reason the factory felt the need to torque the dog crap out of it... I just cut the pipe off as short as I could until I got to a point where the intake came off and then I was able to get a socket on it with plenty of leverage
Old May 18, 2018 | 12:33 AM
Tusc's Avatar
Tusc
If it's that bad with an LS intake, it is worse with the Fast 92 in the way.
With other more pressing projects in the way, I think I'll cut the pipe back for now and when I have nothing better to do take a crack at that bolt.
Thanks for the info!
Old May 18, 2018 | 01:35 AM
grantv's Avatar
grantv
With a few cuts and scratches I was able to get a wrench to the bolt and remove it. Did so, got the tube and bracket out of the way and put the bolt back in place.
On the PS I was able to cut a bit of the tube off. Unfortunately that's it. Never been able to remove the tube, I try once or twice a year.
Old May 18, 2018 | 07:34 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Do you mean A.I.R. system ??...there is no EGR system on the C5's.
Old May 18, 2018 | 07:57 AM
Spaceme1117's Avatar
Spaceme1117
When I had installed my headers, with great difficulty I was able to loosen the bolt on the back of the head and snake out that pipe. You don't have to fully remove the bolt, just loosen it a few turns. The bracket on the AIR pipe is slotted rather than it being a hole which would require removing the bolt entirely.
But the easier and fasted way is to just take off the intake manifold. If I would have done that in the first place, it would have been faster than fighting it with the intake in the way.
Old May 18, 2018 | 10:10 AM
grantv's Avatar
grantv
Just loosening the bolt does sound familiar. And you've given me hope on one day getting that stupid tube out, thanks! Just kept wiggling to PS?
Old May 18, 2018 | 11:46 AM
Spaceme1117
As I recall, it took a lot of persuasion and moving it out little by little as the tube seemed to catch on all the stuff back there.
Old May 18, 2018 | 01:29 PM
Robrote's Avatar
Robrote
That bolt is a PIA with the intake off, let alone on. If you get it off without pulling it, I will commend you with highest praises.
Old May 18, 2018 | 02:11 PM
Spaceme1117
Originally Posted by Robrote
That bolt is a PIA with the intake on, let alone off. If you get it off without pulling it, I will commend you with highest praises.
I was never able to get the bolt out with the intake on so I left it. It was loose but I figured that if it fell out, it would be a problem.
It never came loose and I finally removed the bolt later on when I removed the manifold to install an LS1 steam tube.
I just want to emphasize that if I ever had to do this again, without hesitation I would remove the intake manifold.
To EGR - driver side head bolt?
