headlight stays up
Old May 26, 2018 | 09:47 PM
04zo6lemans's Avatar
04zo6lemans
Cruising
Default headlight stays up
Hey guys here we go again, headlight stays up after turning it off. Drivers side it actually cycles down with pass side and then pops back up and stays there light off. What do you think guys? 2004 commemorative zo6 13k miles
Old May 26, 2018 | 10:21 PM
GCG's Avatar
GCG
Check this Post. It's a reply to the same issues you're having on your driver's side headlight.
Old May 28, 2018 | 02:51 PM
04zo6lemans
Cruising
thanks but no luck
Old May 28, 2018 | 02:53 PM
tnmotown's Avatar
tnmotown
Check out my thread and do they look like this?
https://www.corvetteforum.com/forums...l-the-way.html
I had the same problem when I turned off my headlights. It was that bump stop as mentioned.
I replaced it and now works perfect.
Old May 28, 2018 | 09:31 PM
GCG's Avatar
GCG
Originally Posted by 04zo6lemans
thanks but no luck
Could you please be a little more descriptive?
It's impossible to help you without details.
Did you read the TSB I linked in the thread I gave you in Post 2? It describes the very same behavior you mentioned in Post 1 about your driver's side headlight.
Old Jun 1, 2018 | 09:12 PM
04zo6lemans
Cruising
Hey GCG I took apart the drivers side headlight side and top cover, it appears ok, I don't see anything out of place. The white bump stops I see 2 look like ok.
Old Jun 1, 2018 | 10:08 PM
tnmotown's Avatar
tnmotown
Isn’t there 4 white bumpstops per headlight?
I remember looking at mine and the two top ones were fine, but on the inside bracket on the side is two more. Correct me if I’m wrong.
Old Jun 2, 2018 | 01:44 AM
GCG's Avatar
GCG
Originally Posted by tnmotown
Isn’t there 4 white bumpstops per headlight?...
Yes, there are 4 rubber bump stops per headlight (see pictures below). Check them carefully because, even though they might look fine to the naked eye from a distance, they could be damaged or scored too deep where the limiting contact is made. If you need replacements you can order them from here.
In addition to that, the TSB I mentioned before was released by GM to address the very same symptoms you described. It calls for shimming the driver's side headlight motor to solve this problem.
Old Jun 20, 2018 | 10:05 PM
04zo6lemans
Cruising
Yes you are correct there are 4 bump stops, the 2 on the inside were damaged easy fix. Thanks everyone for your help
To headlight stays up
