Shock Question/Recommendation
Old Jun 10, 2018 | 05:04 PM
Vito52's Avatar
Vito52
Default Shock Question/Recommendation
I need to replace all 4 shocks on my 2003 Anniversary C5 (42,000 miles) as they are beginning to leak. The car is equipped with the magnetic ride shocks and I am wondering if others have replaced these with conventional/adjustable shocks. If so, what brand shock have you used, what have been your experiences with them, and finally what have you done with the left behind electrical connections? Have those disconnected wires caused any issues for the car?
In a similar vein, what are the advantages/disadvantages to replacing the shocks with new electro-magnetic shocks? I understand the price differential, but beyond that, what is the benefit or lack of benefits of doing so?
Thank for your comments, suggestions and recommendations.
Old Jun 12, 2018 | 09:13 AM
Vito52's Avatar
Vito52
Originally Posted by 8VETTE7
You do realize that you need to have access to a Tech II to program out the F55 RPO for those magnetic shocks before you can switch to conventional shocks???
The resistor or sym method does NOT work for the F55 RPO.
If you do not program out the RPO then the vehicle speed will be limited to 80 MPH and you will have a corresponding error message displayed in the DIC.
Thanks for the reply. Yes, I understand that the reprogram will be necessary. However, I was under the impression that it was actually code F45 that had to be deleted as F55 does not appear on the Tech II.
Old Jun 12, 2018 | 09:43 AM
TorqueWinsRaces's Avatar
TorqueWinsRaces
Yeah. Don't waste your money on sims. I have a 2001 coupe with the F45 suspension. I recently swapped the shocks for C6 Z06 shocks and love them. The car handles much better...but I also upgraded the entire suspension at the same time.
Old Jun 14, 2018 | 07:20 AM
Vito52's Avatar
Vito52
What other changes did you make to the suspension? Did you add coil overs or change the springs?
Old Jun 18, 2018 | 05:10 PM
Vito52's Avatar
Vito52
Any suggestions/recommendations as to which brand of shock is best? KYB, Koni, etc?
Old Jun 19, 2018 | 08:53 AM
Vito52's Avatar
Vito52
I personally like the C6 Z06 shocks. You can get all 4 2012 C6Z06 shocks for around $300. JMHO
Are you talking about the AC Delco shocks from the dealer?
To Shock Question/Recommendation
