I just read Bill Curlee's statement on a previous post about removing the cylinder from the assembly. Unfortunately, the cylinder is jammed internally and wont turn to the on/run position; which is why I've removed it. How "stuck" am I? I can't put a replacement cylinder in without removing the original. Maybe I'm better off buying a new cylinder as the original one has been making inserting the key difficult? Several years ago, I took apart the contact part of the switch per Bill's instructions and cleaned up some contacts that had black spots. For these two reasons, am I better off with new both parts of the ignition switch assembly, assuming I can find a locksmith that will reset the tumblers to the original key.
I'm thinking about both as I don't want to be stuck someplace at a bad time. The first time I was stuck was in my garage: the second time 5 miles from home requiring the minimum towing fee. If I can buy both separately, I can have a locksmith re-key the new cylinder to my original keys before mating the two components. I like the original key because it opens the other locks.
Cheapest rekeying of lock cylinder was AMAZINGLY at the GM Dealership. After several locksmiths wanted hundreds of dollars to rekey a cylinder to the original key I called a few GM dealerships. Some were outrageous as the locksmiths but the dealer where I originally purchased the C5 wanted about $28 to reykey the new lock cylinder and in the ignition switch. Call around and see. You might be xurprised.
