"SERVICE ABS" warning
Old Jun 18, 2018 | 11:42 AM
techristian's Avatar
techristian
Default "SERVICE ABS" warning
"SERVICE ABS" warning Was ONE of THREE warnings I got yesterday when I got into my 2002 yesterday.
also "SERVICE TRACTION CONTROL" AND "SERVICE ACTIVE HANDLING"
It was 95 degrees outside yesterday and my car sits in the sun all day. Later on, after supper, the warnings went away.
My "HEADS UP" display gets funky sometimes when it gets hot in direct sunlight also.
DAN
Old Jun 18, 2018 | 11:59 AM
techristian
tHANKS
I will check them later today when it cools down a bit.
Dan
Old Jun 18, 2018 | 12:41 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
If you seem to be getting the codes more when it's hot, I would suggest driving and pulling codes then.
Old Jun 18, 2018 | 01:13 PM
Moved over to C5 Tech.
Old Jun 18, 2018 | 03:23 PM
techristian
my 2002 Corvette Codes June 18 2018
28-TCS C1226 H
60-IPC U1160 H
A0-LDCM B2252 H
A0-LDCM B2282 H
A0-LDCM B2284 H
A0-LDCM B2264 H
A0-LDCM U1064 H
A1-RDCM B2283 H
A1-RDCM B2285 H
A1-RDCM B2265 H
A1-RDCM U1064 H
A6-SCM B2860 H
dan
Old Jun 18, 2018 | 03:47 PM
Smoken1's Avatar
Smoken1
C1226 RF Excessive Wheel Speed Variation. Check the wires connections there. The file I attached will show you what the other codes mean
File Type: pdf
Old Jun 18, 2018 | 11:21 PM
techristian
Thanks. Could it be something as simple as an over or underinflated tire causing an uneven spin?
Dan
Old Jun 20, 2018 | 11:18 AM
aj98's Avatar
aj98
Dan
I would suggest it is possible, at least for underinflated.
My 01 has an issue with a slow leak in the LF.
If I let the LF drop below 23 psi, I'll start getting the ABS/TC messages at start, along with the sliding car warning light. (the other 3 tires are stable at 30psi)
It clears with the reset button, the light stays illuminated, and the DIC message pops back up a few minutes later.
Reinflate the tire, the message and the light both go away until that tire leaks down to <= 23 again.
Old Jun 16, 2020 | 12:27 PM
techristian
Resoldered the module and reinstalled. It is working great now.
Dan
Old Jul 10, 2020 | 07:51 PM
RED Coupe's Avatar
RED Coupe
Default SERVICE ACTIVE HANDLING< TRACTION CONTROL etc msg's.
DAN
I randomly get the same messages "SERVICE TRACTION CONTROL" AND "SERVICE ACTIVE HANDLING"when I first start the car. Turn car off and immediately restart and everythings fine, no messages. i'm original owner, 30K miles, immaculate, impeccably serviced. Replaced front pads last year....car driven VERY little. Is this something needing serious attention or messages based on age and mileage. Car runs flawlessly. Appreciate guidance...Bob
Old Jul 10, 2020 | 07:55 PM
Old School's Avatar
Old School
Did you try pulling the DIC codes?
Old Jul 10, 2020 | 07:59 PM
RED Coupe's Avatar
RED Coupe
No haven't done that....truthfully, embarrassed to say dotn't know how.
Old Jul 10, 2020 | 08:10 PM
Old School's Avatar
Old School
Old Jul 10, 2020 | 08:31 PM
RED Coupe's Avatar
RED Coupe
Originally Posted by Old School
THANK YOU!!! Great video. Do you suggest I clear the codes or just write down the code information? I assume there
are places I can get interpretation of any code. True?
Old Jul 10, 2020 | 08:45 PM
Old School's Avatar
Old School
I would write them down and then clear them. You will probably have some old codes that are no longer valid, you want to see what returns after you drive the car a bit. The codes you are most concerned with at the moment are the TCS codes.
DIC codes listed here: http://www.stengel.net/diccodes.htm
Old Jul 10, 2020 | 08:48 PM
Old School's Avatar
Old School
What year corvette do you have?
Old Jul 10, 2020 | 08:49 PM
RED Coupe's Avatar
RED Coupe
Thanks very much....this has been extremely helpful and informative. Ok, will do as advised, will write down and then clear. See what
happens after few start/stops and driving. Thank again, much appreciated.
To "SERVICE ABS" warning
Old Jul 10, 2020 | 08:52 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Let us know what DTC’s you have !!...if you want to drive it down to central NJ I can take a look at it for you !!
RED Coupe's Avatar
RED Coupe
2001 Coupe, Torch Red, Black Interior, 1SC package, Z51 Package, 6 spreed...stock, other than Corsa Exhaust and Magnaflow xPipe. 30K miles.
I'm original owner....old guy now!!!! Heated garage since new....never seen snow nor rain. Lives under cotten cover on trickle charger.
Old Jul 10, 2020 | 08:55 PM
RED Coupe's Avatar
RED Coupe
Really nice gesture...thank you. Where are you? Oh, see you're in Monmouth, where about?
