spark plug blew out
Old Jun 21, 2018 | 03:57 PM
twisterclay777's Avatar
twisterclay777
6th Gear
Default spark plug blew out
2004 vet had ticking noise and blew out #1 plug. Replaced it but it wont go in very far.
Old Jun 21, 2018 | 04:07 PM
Simtech's Avatar
Simtech
Mainly just subscribing to find out what happened. Is it possible that the plug was backed out for a while, the ticking was an exhaust leak as the plug got close to coming completely out and the threads have carbon built up in them from the plug being backed out. Where the threads on the plug that blew out damaged? Pics of the plug and head would also be great.
Old Jun 21, 2018 | 04:11 PM
Smoken1's Avatar
Smoken1
You can buy a thread chaser to clean the threads in the head
Old Jun 21, 2018 | 05:44 PM
UM Rebel's Avatar
UM Rebel
Had that happen on my '79 C3 right after an engine build. My guess is mechanic didn't tighten it well. Had to run a thread chaser and install a new plug. All was well then.It's a pretty shocking sound when a plug blews lit that!
Old Jun 21, 2018 | 06:09 PM
99blkfrc99's Avatar
99blkfrc99
Great excuse for some new heads and cam. 😀
Old Jun 22, 2018 | 08:48 AM
dankhts's Avatar
dankhts
had it happen to me at the track, blew out #7, chased the thread and put in another.... blew it out again,,, pulled the head and heli coiled it....
Old Jun 22, 2018 | 09:27 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Heli Coil it !!...only way to fix it properly...BIG problem with the Ford 4.6, 5.4, and 6.8 Triton engines...blew out one on my old 2005 Escape daily driver. Design flaw !!
Old Jun 22, 2018 | 12:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Plug chaser tap! Use plenty of grease on the tap to catch the dirt/carbon. If the plug was not tight on the head, the gasses would escaped around the threads and have contaminated the threads with carbon.
You MUST clean them or risk stripping them out. Use antiseize on the new plug with the proper torque so the taper seat seals against the head surface taper and the plug is properly tightened.
Old Jun 22, 2018 | 09:34 PM
twisterclay777
6th Gear
Plug that blew out.
Old Jun 22, 2018 | 09:59 PM
twisterclay777
6th Gear
Here are pictures of #1 plug that blew
Old Jun 22, 2018 | 11:06 PM
C5 Diag's Avatar
C5 Diag
I would be more concerned of what the threads in the cylinder head look like !!
Old Jun 23, 2018 | 01:07 AM
twisterclay777
6th Gear
Default It is that cylinder under the alternator.
It is so hard to see. But it feels like threads are good.
Old Jun 23, 2018 | 01:26 AM
C5 Diag's Avatar
C5 Diag
Well try it if you think it's good...if the plug feels like it's starting to cross thread you can try a tap. Just make sure you get any metal out of the cylinder...I used my blow nozzle. If it blows out again it's heli coil time. Dorman and OEM sells a kit. Pep Boys or Autozone might stock it.....just not try to be too far from home if it happens...I was 40 miles away !!
Old Jul 14, 2018 | 03:23 PM
twisterclay777
6th Gear
Default heli coil day
Well here I go. Heli coil day. I will get back to you. Thanks for suggestions.
Old Aug 2, 2018 | 08:47 PM
twisterclay777
6th Gear
Well I want to thank you all for telling me about the Heli coil. It worked and Vet running REAL Good now. I watched a video on how to put grease on the tap and only do about five turns at a time, then back it out, clean off shavings that stuck to grease. Re grease and do it over and over. It worked perfect. Appreciate your knowledge. Clayanna
To spark plug blew out
