2003: Question After Running Codes
Old Oct 21, 2002 | 11:07 AM
luckyj's Avatar
luckyj
Default 2003: Question After Running Codes
I noticed that after running a code check (found none) that when I turn my key off after the last module says "no codes", I get a Charge System Fault message. Now if I wait unti the code system goes to the Manual Diagnostic Mode and then turn off the key, the Charge System Faukt does not appear. I'm sure there is no problem, but just wondered if anyone else noticed this when running a code check. Thanks.
Jim
