TPMS question
Old Jul 12, 2018 | 09:48 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default TPMS question
If a sensor is going bad, does it just quit completely, or does it give erroneous readings for a while, before dying?
Old Jul 12, 2018 | 10:11 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If I can remember mine just died...no warnings !!...might as well replace them all...the others aren't to far behind !!
Old Jul 13, 2018 | 08:15 AM
leadfoot4's Avatar
leadfoot4
I know, but it's not like my "good old days", where I had access to a tire machine, at the corner gas station, to break down the upper beads and sneak the old sensors out, and the new ones in. Believe me, if I could easily do this myself, I'd do it in a heartbeat! When you have to pay people to do things for you, it changes your outlook on things....you aren't as willing to just throw parts at a situation, and hope you guessed correctly.
Old Jul 13, 2018 | 08:23 AM
C5 Diag's Avatar
C5 Diag
I'm fortunate to have a co worker who owns an Aamco Transmission on the side and the shop is a mile from my house so I have free reign on the tire machine....as far as throwing parts at a situation I see that WAY too often on this forum...but the part stores LOVE it...LOL !!
Old Jul 13, 2018 | 12:45 PM
grantorino's Avatar
grantorino
My TPMS started showing a left rear tire flat when it was at 30 PSI. I ordered and installed 4 new sensors. My car is a 1999 so the batteries have a long life but eventually fail.
Old Jul 13, 2018 | 06:35 PM
leadfoot4's Avatar
leadfoot4
My current sensors are about 10 years old. And in my case, my RF tire starts out showing a pound, sometimes two pounds low, then after about 4-5 miles of driving, it "catches up" to the LF.
Old Jul 13, 2018 | 09:43 PM
awches's Avatar
awches
Mine is starting to give me a " Service Tire Monitoring Sys" or to the like. Then goes off. 1st time, I pulled the codes and saw it was the right front failure. Cleared the code and then a week later, came up again so I quickly went to the tire pressures on the GAUGE readout and was Getting RF XXXXXX But the LF was reading 32 psi. As was the backs. Then a few miles down the road it cleared and started reading normal. I did get a new on in this week and will change it sooner or later.
Old Jul 15, 2018 | 08:24 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
All of the above!
I had a C5 'zombie' TPMS. After it failed, it was dead for several months.. then it would wake up some days.. Readings could be off.. or exactly right... then it would die again.
To TPMS question
