Electrical issues
Old Jul 28, 2018 | 09:16 AM
Marion Wright's Avatar
Marion Wright
5th Gear
Default Electrical issues
Probably no relation but the AC display went out and also the driver's door quits working I can wiggle the boot between body and door and lights will come on and switch it start working again which cars haunted 58000 miles I bought it when it had 48, 000 mi in December 31st 2012 anybody help would be deeply appreciated have a great day guys and be careful out there keep it between the mayonnaise and mustard and be sure and watch the fools out there that don't know how to drive? Thanks again to all have a blessed day Marion. Any suggestions would be deeply appreciated? Thanks again!
Old Jul 28, 2018 | 02:46 PM
mmartinez's Avatar
mmartinez
You will have to take apart the connector that goes from the door to car and search for bad electrical contact between pins and sockets usually the socket. After locating the suspected bad connection you can carefully tighten the connection by squeezing the socket with a pair of needle nose pliers. The AC display will have to be replaced or repaired by resoldering all the surface mount resistors located on the pc board.
Old Jul 28, 2018 | 03:14 PM
Smoken1's Avatar
Smoken1
Here is a thread on how to fix the AC control problem...
https://www.corvetteforum.com/forums...splay-fix.html
Old Jul 28, 2018 | 03:20 PM
GCG's Avatar
GCG
Old Jul 28, 2018 | 03:29 PM
GCG's Avatar
GCG
Originally Posted by Marion Wright
...the driver's door quits working I can wiggle the boot between body and door and lights will come on and switch it start working again...​​​​​
This problem has been extensively documented by Bill Curlee and you can read more here. It is usually caused by bad contacts in a connector within the doors' rubber accordion.
The female pins of the connector on that wire harness get deformed, causing bad contacts and isolating the door control module. In addition to that, this could also cause a loss of communication/corruption in the Serial Data Bus affecting all modules linked by it.
Check the connectors for deformed pins. If bad pins are found you would need to repair the connector, fixing the female pins so they have a positive grip, or replace it. If you want to replace the connector take a look at this post for some ideas.
If connectors are fine, then the problem should be downstream the connector up to the door control module, but considering you can make it work by wiggling the rubber accordion, most probably you have bad contacts in the connector.
To Electrical issues
