Autocrossing the C5
Old Aug 3, 2018 | 01:23 AM
rcace44's Avatar
rcace44
Default Autocrossing the C5
I have been Autocrossing my 2003 C5 Corvette which is stock, and has original equipment replacement Michelin Tires with 189 MPH speed rating. My normal cold driving pressures are 32-33 psi front and 33-34 psi rears. What tire pressures should I be running cold on these tires when I Autocross?
R/C
Old Aug 3, 2018 | 09:16 AM
Gordy M's Avatar
Gordy M
If those are the PS2 Michelin's then starting cold at 30F and 28R would be a good starting point. I have a 2000 FRC and have run both the Stones RE71R and BFG Rival S tires, I usually start either of them at 26F and 24.5R cold. If you are using Nitrogen then add 2 lbs to the pressures. After my first runs I am usually at 30F/27.5R on pressures with air.
Old Aug 3, 2018 | 10:05 AM
rcace44's Avatar
rcace44
Thanks for the reply Gordy. They are PS2's, Run Flats. You have a 2000 C5, what is a FRC model?
Old Aug 3, 2018 | 10:17 AM
Tsumi's Avatar
Tsumi
FRC is Fixed Roof Coupe, the style which later became used for the Z06.
Old Aug 3, 2018 | 10:35 AM
rcace44's Avatar
rcace44
Thanks! I have a friend with one of those, but never heard the term FRC before.
R/C
To Autocrossing the C5
