ABS and Traction
Old Aug 4, 2018 | 02:37 PM
Comanche63's Avatar
Comanche63
3rd Gear
Default ABS and Traction
Was driving down the road legal speed and my service ABS and Traction Control came on the computer indicator. After stopping and then restarting the indication did not come back on. I have a 2000 model. Any info will help.
Old Aug 4, 2018 | 02:53 PM
Smoken1's Avatar
Smoken1
Use your DIC and pull the codes..
Old Aug 9, 2018 | 10:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Pull and post the DTCs so we can logically assist you.
Old Aug 10, 2018 | 06:00 PM
Comanche63's Avatar
Comanche63
3rd Gear
These are the codes I pulled. 28-TCS C1226 H, AO-LDCM B2252H-B2282H-B2284H-B2264H-U1064H, A1-RDCM B2283H-B2285H-U1064H,
Old Jun 9, 2020 | 09:18 AM
8junior3's Avatar
8junior3
7th Gear
My 2000 is doing the same- intermittent ABS/Traction control error- Code C1226- Pre the BlueDriver code reader app it is saying.
Faulty Front Hub Assy
Faulty Front wheel speed sensor
Faulty Front wheel speed harness.
Old Jun 9, 2020 | 06:35 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
For the most part when ever you have a WSS DTC for the front wheel signal data, its caused by damaged/ spread apart electrical connector FEMALE PINS. There are TWO female pin connectors for each front wheel. One on the Jumper Harness connector and one on the main WSS harness on the Frame.
Examine the female pins and look for damaged female pins that will be spread apart. Do a pin PUSH PULL TEST for every female pins and repair /replace any that fail.
Old Aug 2, 2021 | 03:04 PM
TCFS's Avatar
TCFS
2021 C5 of the Year Finalist - Unmodified
just to keep track of the thread
To ABS and Traction
