Battery Test Question
Old Aug 10, 2018 | 10:16 PM
silverbird's Avatar
silverbird
St. Jude Donor '08
Default Battery Test Question
I have an older battery that I recently had tested at the local parts store.
I keep the car on a trickle charger.
The battery tested fine.
When I took it to the store, it was fully charged from the trickle charger.
Is it possible to get false battery test results since it was just taken off the charger and fully charged?
Would I get a more accurate reading if I have it tested after not being on the trickle charger for 3-4 days?
Thanks,
Silverbird
Old Aug 11, 2018 | 06:06 AM
Grandpa1's Avatar
Grandpa1
I agree with 8VETTE7.
Older batteries scare me. If I was having doubts about it I would get rid of it and buy a new one.
I hate it when a battery fails. You just cannot prepare for it other than carrying a bunch of stuff with you.
Peace of mind to me is important.
Good luck!
Old Aug 11, 2018 | 06:11 AM
silverbird's Avatar
silverbird
St. Jude Donor '08
Thanks for the information.
Much appreciated.
Time for a new battery.
Silverbird
Old Aug 11, 2018 | 07:37 AM
WillItFloat's Avatar
WillItFloat
I had a similar experience as 8VETTEZ with my 1999 convertible. I'm embarrassed to admit that I may have lived with it for five years.
I bought the car from a dealer who was selling it on consignment in 2013. The car would not start the first time I looked at it. They charged the battery and it started fine. A few days later I went back to look at it again and again it wouldn't start. I ended up buying the car but I insisted they install a new battery which they did.
After that I had no problems with the car if I drove it every few days. If I let it sit too long it would not crank. I assumed there was a parasitic draw somewhere and I read a lot about the issue on this forum but I never did anything about it. Finally, after taking it out of storage this spring, the battery would not hold a charge. I bought a new battery and, since then, the car can sit for two weeks and will still start. I suspect that the new battery the dealer installed was questionable from the start.
Old Aug 11, 2018 | 08:16 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Hello !!
You said you took the battery off the trickle charger and had it tested. The test is NOT done on a fully charged battery !!...Did you remove the “surface charge” before testing ??...you HAVE to or you will not get an accurate reading from the load tester. I turn on the headlights for a few minutes to remove this surface charge. If you don’t a weak battery will test normal !!
Old Aug 12, 2018 | 12:09 PM
lionelhutz's Avatar
lionelhutz
If they tested it with an actual real load tester that draws a decent current then the tester will remove any surface charge just as good as turning on the headlights will....
To Battery Test Question
