Metal in oil filter
Old Sep 16, 2018 | 09:32 PM
apex26's Avatar
apex26
Don't want to be alarmist. Fine metal is pretty normal. Sometimes when I change oil I let the dirty oil sit in the pan a few weeks, then pour it off and see what settled--which typically is really fine gray stuff, like soft babbitt material from bearings, which used to contain lead . But, shavings are not normal wear--they are excessive wear somewhere, and the shavings can cause excessive wear in lots of other places. Excellent candidate for Blackstone. Mines always come back from Blackstone less wear than normal, and that peace of mind alone is worth the cost. If there is a problem, diagnosing it early could save thousands.
Old Sep 19, 2018 | 07:07 PM
Awkwardcrane's Avatar
Awkwardcrane
Are you hearing piston slap? It stops after oil is up to running temp?
Old Sep 20, 2018 | 03:40 PM
bwill03z's Avatar
bwill03z
It goes go away after the engine is up to temp but it definately isn't piston slap
