Harmonic Balancer confusion?
Old Sep 14, 2018 | 04:57 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
there is a thing called "google it" if you install a aftermarket balancer you are at the mercy of whatever God you believe in !!!! again the LS engine is externally balanced by the damper and flywheel setup !!!!!!!!!!!!!
Old Sep 14, 2018 | 05:08 PM
FreeC5inAZ's Avatar
FreeC5inAZ
LOL...can't find anything to support your argument, can you?
Old Sep 14, 2018 | 06:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
many !!!!!!!!!!!!!! (don't care I know what I know) !!!!
Old Sep 14, 2018 | 06:07 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by 99blkfrc99
Just from expirience, my ARP bolt did back out after about 8k miles. So I then pinned the crank and so far no issues.
Just curious, how tight did you torque it?
Old Sep 14, 2018 | 06:12 PM
leadfoot4's Avatar
leadfoot4
Originally Posted by Smoken1
Yea, lots of them
then it's balanced !!!!
According to the factory shop manual, the stick shift cars are "hot balanced" after being assembled as a unit, and the small holes are used to insert equally small "balance weights", to allow for that last little bit of balance correction. I installed an ATI balancer on my car, and it has no provision for such things....
Old Sep 14, 2018 | 06:18 PM
monteholic's Avatar
monteholic
https://ls1tech.com/forums/generatio...ced-motor.html
Old Sep 14, 2018 | 08:03 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
interesting that GM themselves says otherwise. Not that I trust GM or anybody else for that matter. I got sick and tired of looking for a procedure to install the thing so I put the damn thing on. Same went for my clutch. I switched to a LS7 clutch and aluminum flywheel and threw it on the car. It spun to 7200 without any problem. But I've always wondered about this.
Old Sep 15, 2018 | 10:34 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Using your words of "google it"
The LS1 engine is an internally balanced platform.
The reason that LS1 balancers new or aftermarket have holes in them is because they are balanced to themselves.
As someone else already mentioned, if it was an externally balanced engine the engine would a have key on the damper.
You can choose to argue this in whatever fashion you'd like.
OP, don't turn this into a rocket science that is not needed. Change your seal and put the thing on and torque to ARP specs and get to driving.
Old Sep 15, 2018 | 11:44 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
https://www.cadillacforums.com/forum...-balanced.html
Old Sep 15, 2018 | 11:49 AM
Mr. Black's Avatar
Mr. Black
https://help.summitracing.com/app/an...l-vs.-external
Old Sep 15, 2018 | 12:25 PM
jpb1978's Avatar
jpb1978
I believe the engine is internally balanced, if the harmonic balancer was part of the balance it would be keyed like it was on older engines like the 454 that was externally balanced. Everything I have read on the internet except a few posts in this thread have said LS engines are internally balanced. Here are some links, the first says LS engines are internally balanced. I converted 454 from external to internal balance, it required new balancer and flywheel and having the internals balanced with heavy metal, did not need a clutch because it was a marine engine.
The second has lots of good LS engine info and says stroker engines are balanced with heavy metal, engines balanced with heavy metal are internally balanced.
http://blog.jepistons.com/everything...-engine-family
Old Sep 15, 2018 | 02:09 PM
vettenuts's Avatar
vettenuts
This is your answer. I also installed an ATI, no provision for moving weights as described in the GM service manual. You have the same situation with the Powerbond.
You should be using the ARP lube on the ARP bolt threads, under the washer and under the bolt head. It should be provided with the bolt.
I would consider swapping the front seal since it is fully exposed. Since the Powerbond is a keyed damper, I would also consider the ATI pin kit that takes advantage of the key way in the damper hub.
Don't use ls1howto.com for instructions. Get a proper tool to press on the new damper. Follow the service manual up until the point that the new bolt is installed and then follow the tightening sequence for the ARP bolt.
Old Sep 15, 2018 | 03:25 PM
  #33
Pounder's Avatar
Pounder
1/4 mile/AutoX
the keyway in engines is because of the timing marks !!!!!!!
Old Sep 15, 2018 | 03:38 PM
  #34
Walt G's Avatar
Walt G
The LS1 engine is internally balanced, and the flywheel and harmonic 'balancer' (really just a harmonic 'damper' on this engine) are neutrally balanced by design.
However, some of the manual transmission engines were failing a GM spec for vibration at the seat mount location at idle. Auto trans cars were passing the spec.
GM decided to do the 'hot balance' fine tuning on manual cars only. I hear it was a tight GM NVH spec that only some manual cars were just barely failing. Once you replace your flywheel or pressure plate that balancing done by the factory in the original balancer is meaningless anyways because it's a package deal with the other end of the engine.
I know a guy who worked in the engine test department for GM during development of the LS1.. they never bothered to do this fine balancing on any engine they tested. He assured me not to worry about it.
I hope that helps.
Old Sep 15, 2018 | 04:35 PM
  #35
LSKevin117's Avatar
LSKevin117
Welp, it sure looks like I've started some arguments, whoops! But thanks for the info guys, I'm leaning towards the idea that it won't matter how the new one goes on. I have no way to adjust it anyways. I got my car up off the ground now and I'm as ready as I'll ever be to take on this project. I may update after finishing and driving for a while. Hopefully it all goes smoothly. Thanks again!
Old Sep 15, 2018 | 04:37 PM
  #36
feeder82's Avatar
feeder82
I also have done the balancer and ls7 clutch without any worry about indexing or matching the balance, no issues
Old Sep 15, 2018 | 04:42 PM
  #37
feeder82's Avatar
feeder82
not completely correct, the keyway is there on most balancers because they are not a slight interference fit like a LS balancer the keyway is neeeded to keep it from spinning
To Harmonic Balancer confusion?
Old Sep 15, 2018 | 09:27 PM
  #38
Pounder's Avatar
Pounder
1/4 mile/AutoX
I will disagree again !!!!!!!!!!!!!!!!!!
Old Sep 16, 2018 | 08:48 AM
  #39
leadfoot4's Avatar
leadfoot4
The crank is also has "keyways" because the oil pump is driven off the nose of the crank. The ATI pinning kit locates off the oil pump key, and then locates the pin for the balancer, accordingly....
Old Sep 16, 2018 | 02:54 PM
  #40
jpb1978's Avatar
jpb1978
This is what the harmonic balancer for an externally balanced engine looks like, see the big counter weight cast into the balancer.
