Fan controller
Old Sep 13, 2018 | 08:14 PM
TheBigDog's Avatar
TheBigDog
Default Fan controller
Looking for a switch to turn fans on manually when Turbos create too much heat. As I understand it fans come on at 35mph. I have seen them advertised but can’t recall vendor. I would like to be able to turn on manually if needed.
thanks in advance
Old Sep 13, 2018 | 11:08 PM
foggy's Avatar
foggy
I like my SacCity Corvette manual fan ON switch.. It uses a wireless keyfob like deal..
I can turn 1 of the fans on HIGH at anytime.. Even with engine off/ key on.
Old Sep 15, 2018 | 04:10 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Originally Posted by 8VETTE7
Fans as installed from the factory are 'Commanded OFF' at 35 mph ir-respective of coolant temp.
I believe what you are looking for is a product called "coolit" from SacCity Corvette.
http://www.saccitycorvette.com/COOLITv2.html
It does not automatically turn the fans on. You have to press the button on the remote to turn them on.
Recognize that this may interfere with the normal flow of air through the "free-wheeling" fans when the car is above 35 MPH.
GM felt that the air flow through the fans with them free wheeling with vehicle speed above 35mph provided better cooling than with the fans operating. As always YMMV...................
Thank you 8VETTE7 for letting TheBigDog know where to find our Coolit.
Just to let you know what we found out when we were doing all the testing on the Coolit, we found that while cruising at 40 mph in 100 + degree weather here in Sacramento the temp on our C5 zo6 would run around 215+. When we turned on the Coolit the temp came down to around 205.
This test C5 is running a 440ci, big cam and Ron Davis radiator and it runs hot. In the tune we have the fans set to come on at 205 and off at 195 instead of the 226 factory setting, but after 35 mph the fans dont come on unless we use the Coolit. So the Coolit really helps out on C5's that
have stock fan settings.
Thank you,
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Sep 15, 2018 | 04:11 PM
SacCityCorvette
Supporting Vendor
Thanks Foggy for the good word on your Coolit!
Christian
Old Sep 18, 2018 | 07:41 PM
TheBigDog's Avatar
TheBigDog
Thanks for the write up on your Coolit product. You have me sold. I will be ordering one soon
TheBigDog
QUOTE=SacCityCorvette;1597989465]Thank you 8VETTE7 for letting TheBigDog know where to find our Coolit.
Thank you,
Christian[/QUOTE]
Old Sep 18, 2018 | 09:23 PM
SacCityCorvette
Supporting Vendor
Thank you TheBigDog!
To Fan controller
