My 99 Coupe Won't Crank
Old Sep 17, 2018 | 10:08 AM
bcresc's Avatar
bcresc
Default My 99 Coupe Won't Crank
My 99 Automatic Coupe refuses to crank. The only codes I see are B2282, B2283, B2284, B2285, and U1064. These are all history codes. I know that the battery is good. I don;t know where to start troubleshooting the problem. Any help is really appreciated.
Old Sep 17, 2018 | 11:33 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Give me an E-Mail, address and I will send you a schematic that you MUST have to fully understand the cranking and theft deterrent stuff... Once you have that schematic, it will be easy for me to lead, guide and direct you to a solution.
If you turn the lights on do they function and shine bright??
Does it not crank at all??
The very FIRST thing that you should do is make sure the battery terminals are clean and properly torqued on to the battery Torque them to 11 ft/lbs.
Bill
Old Sep 17, 2018 | 01:00 PM
bcresc's Avatar
bcresc
Bill - Thanks for the quick reply. My e-mail is bob_cres@verizon.net
The lights work normally and they shine bright. In fact, it seams that everything else is working normally.
Battery is good and fully charged The terminals are clean and tight.. I have tried multiple keys.
Bob
Old Sep 17, 2018 | 01:01 PM
mmartinez's Avatar
mmartinez
The first thing to do is to rule out the starter/solenoid, if knowledgeable about digital multimeter connect positive meter lead to switch terminal on solenoid, usually a purple wire and the negative lead to negative battery terminal select dc volts. Have someone try to start the car while you observe the meter, you should have 12 volts, if 12 volts is present then all the upstream interlocks are OK, then it could be your starter/solenoid or you could have loose battery cables or loose battery cable connection on the starter solenoid. If 12 volts is not present on the purple wire, it could be TDR, neutral safety switch, the vats key reader, and or dirty electrical contacts in the ignition switch. Hope this helps, good luck.
Old Sep 17, 2018 | 01:07 PM
bcresc's Avatar
bcresc
Thanks Martin - I appreciate the help. Will check it out.
Bob
Old Sep 17, 2018 | 01:27 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Schematic sent:
Look on that schematic. Check to see that Fuse/s 14, 50 & 52
Fuses 14 & 50 will be hot when the key is in the ON/Run position. Fuse 52 is hot all the time
There are 2 test points on top of each fuse. Measure both test points to ground. to see if you have the proper voltage on BOTH test points.
The theft deterrent relay is in the passengers foot well on the fire wall above the BCM It has four wires. If you GROUND the yellow/black wire to ground, you will be able to BY PASS all of the cars security functions. If it starts after you ground that wire, you have a BCM Security issue.
Bill
Old Sep 17, 2018 | 04:20 PM
bcresc's Avatar
bcresc
Got it. Thanks Bill - Will check it out.
Old Oct 18, 2018 | 04:48 PM
bcresc's Avatar
bcresc
Bill - Just had a chance to run through your instructions. Been under the weather lately. Anyway, I get battery voltage on both sides of 50 and 52 but nothing on either side of 14 (ignition in the run position). I pulled the fuse and it checks out OK. I assume that I should have seen voltage on one side even if the fuse were bad. Right?
I grounded the yellow/black wire on the theft deterrent relay and the car still would not crank. Just hear the clicking from the relays. Any suggestions as to the next step?
Thanks,
Bob
Old Oct 19, 2018 | 12:11 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you do NOT have voltage on fuse 14 when the ignition switch is placed in the START position, the ignition switch is bad OR the IGN2 Fuse is not providing power to the ignition switch. Without power going all the way through the circuits to the TDR, jumpering the yellow black wire will NOT provide any action.
Old Oct 19, 2018 | 02:10 PM
bcresc's Avatar
bcresc
Sorry, but just to be clear, when you say "START" position, is this the same as the On/Run position mentioned earlier?
Old Oct 19, 2018 | 02:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO,,,,,,, C R A N K position It ONLY supplies voltage to fuse 14 in the CRANK/START position.
BC
Old Oct 20, 2018 | 10:36 AM
mmartinez's Avatar
mmartinez
Have you heard of wack a starter, have someone try to start the car while you smack the starter with something like a wooden broom handle with a hammer. This is not very technical, but is advise given here on the forum, as starter/solenoids do fail especially if the car has long tube headers. I only give this advise because you state that you can hear relays clicking when you try to start your car and that is a good sign that most things are working correctly. Hope this helps
Old Oct 20, 2018 | 05:29 PM
bcresc's Avatar
bcresc
I do have battery voltage on 14 when in the START position. Not sure what this means. Any more suggestions? Thanks, Bob
Old Oct 20, 2018 | 05:32 PM
bcresc's Avatar
bcresc
I haven't tried whacking the starter yet, but I am looking for sledge hammer to use on this thing. I used to love working on our C3's in the day. So simple back then.
Old Oct 20, 2018 | 09:16 PM
mmartinez's Avatar
mmartinez
Your right about that, imagine working on even newer cars. Did you have a chance to attach a dvm to the switch terminal purple wire on the starter solenoid and verify power when you turn the key to the crank position. I know that most people dread the thought of having to replace starters or solenoids on their cars but they do fail. Keep the faith, I know you will find the cause of your no crank problem.
Old Oct 26, 2018 | 09:57 AM
bcresc's Avatar
bcresc
Still stuck for an answer as to wy my '99 auto coupe won't crank. Any more suggestions?
Thanks to Bill C and MMartinez.for their help so far.
Old Oct 26, 2018 | 12:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
SIMPLE as this.. Get a DC Voltmeter, attach the POS lead to the PURPLE WIRE on the starter solenoid. Its not actually purple where it attaches to the solenoid. I thinks its a brown or dark read color because it turns into a fuseable link and that lead off the fuseable link is a weird color.
Attach the NEG lead to chassis ground. Have someone turn the ignition switch to crank and do all the stuff that you NORMALLY do to crank the engine. (shifter in park, foot on brake, ect...) You should see battery voltage on that wire if the starter safety circuit is working.
If you see battery voltage on that solenoid wire, you may need to try the starter THUMP TEST!
BC
To My 99 Coupe Won't Crank
Old Nov 9, 2018 | 11:54 AM
bcresc's Avatar
bcresc
Turned out to be a bad starter. Thanks for all the help...
Bob
Old Nov 12, 2018 | 12:44 PM
mmartinez's Avatar
mmartinez
Glad to hear that you found the problem with your car and thanks for the update, to many forum members don't take the time to post after they have found the cause of there particular problems.
Old Nov 12, 2018 | 01:40 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
