Heads & Intake Swap = Low Compression
Old Sep 17, 2018 | 08:51 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
Default Heads & Intake Swap = Low Compression
So I completed a heads and intake swap on my 98. Changed to 799 heads and LS6 intake. Connected everything back up, and it wouldn’t start. Low compression.
After a bit of research, we found that changing to the newer heads meant we should have changed to the 7.375” pushrods instead of reusing the 7.425” pushrods. We order up the new pushrods and installed them today.....same result.
Has anyone gone through this LS6 top end swap and come across this? Are we missing something? Need advise.
Old Sep 17, 2018 | 10:06 PM
StingrayRebel's Avatar
StingrayRebel
are you positive it's due to low compression and not a fuel/spark issue?... did you attach the ground on the back of the driver side head?
Old Sep 17, 2018 | 10:13 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Chris, I agree with Neutron. What makes you certain off the bat that you have low compression? I think you need to be investigating other avenues.
I'm sure you'll get this resolved in no time.
Old Sep 17, 2018 | 10:24 PM
Chris Draper
it has fuel and spark. We checked that first. Yes, I did attach the ground to the driver’s side head. We did a compression check and it only had 50 pounds.
Old Sep 17, 2018 | 11:02 PM
StingrayRebel
50 on all cylinders?... I would pull all the rockers and do a leak down test, that will tell you if they are holding pressure or not... if that checks out then move on to the pushrods, you should buy an adjustable pushrod tool and measure for the correct length
Old Sep 18, 2018 | 06:34 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I AGREE!!!
Pull the rockers and do a leak down test. You could have bent the intake valves. If pulling the rockers doesn't restore the cylinder pressures, be prepaired to pull the heads back off if pulling the rockers does not restore compression.
Old Sep 19, 2018 | 04:24 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Info about switching to the 7.375” pushrods is probably correct but it may be worth $10-15 to buy a pushrod length check tool; especially if you plan on other engine work later including cam swaps, lifter swaps, etc.
Hopefully the longer pushrods are just keeping the valves from seating and that the valves are not bent.
Good luck and hoping for an inexpensive fix.
Old Sep 24, 2018 | 05:44 PM
1997 C5's Avatar
1997 C5
I thinking doing what you did, done the road I want to replace heads w/799, LS6 intake, possibly headers, & tune. How much HP do you gain just replacing the heads and intake?
Old Sep 25, 2018 | 11:19 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any up-date on the issue??
Bill
Old Sep 25, 2018 | 01:19 PM
Robrote's Avatar
Robrote
Interested as well. I watched the video and that car had zero compression. Either every valve was bent (which I doubt since he had the springs off and would have assumed you could see if they were bent that bad), or it's some push rod issue. I would have liked to have seen the engine crank with the valve covers off to see if the rockers were allowing the valves to close. Other than those two things, I can think of nothing else it could be.
Old Sep 25, 2018 | 06:29 PM
turabo87's Avatar
turabo87
Good luck Chris. I follow you on YouTube, interested on your outcome. Hope you have her up and running soon.
Old Sep 25, 2018 | 08:49 PM
Mr. Black's Avatar
Mr. Black
As Rob said, after seeing the video that car had zero compression from the get go of cranking it. Either the valves got bent from hand cranking the engine or the valves were damaged before installation.
I don't buy the push rod being too long possibility at this time. They would have to have milled a metric ton off of his 243 heads in order for it to have had that much effect on push rod length. I've run 7.40 push rods on stock 243 heads before with a decent sized cam.
Just rambling here, and dying to know the resolution. Sounds like it might be a bit longer before he can get to it.
Old Sep 27, 2018 | 02:52 PM
Route99's Avatar
Route99
Really curious now.
To Heads & Intake Swap = Low Compression
