All Service Lights On?
Old Sep 20, 2018 | 01:35 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default All Service Lights On?
2002 ZO6 it has air bag light, traction control, abs, fuel gauge to empty, water temp 260, oil pressure 0, radio no display, and no power windows or locks. Also has service vehicle soon, low fuel, service traction control, abs, active handling reduce engine power. If I go into the service codes on the dash all systems say no command? Anybody ever seen this problem?
Old Sep 20, 2018 | 04:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its JUNK... Ill come pick it up before the neighbors complain.. Where do you live? I have a flat bed. Ill only charge you $150 to tow it off..
LMAO!! On a more serious note,,, Sounds like you have a serial data buss issue. Is the carpet in the passengers foot well WET?? Check under the carpet also. You could also have an issue with one of the door control module power plugs.
Do you have all of the door control functions?? Windows and locks??
Open BOTH doors and shake the hell out of the rubber accordion tube between the doors and see if things change when you turn it off and back on..
BC
Old Sep 20, 2018 | 08:45 PM
Corvette ED
LMAO!! On a more serious note,,, Sounds like you have a serial data buss issue. Is the carpet in the passenger's footwell WET?? Check under the carpet also. You could also have an issue with one of the door control module power plugs.
BC
The carpet is wet on the passenger side. The car has a 3-year-old Optima battery in it. It took the battery out and checked the cowl drain. I also checked the ac drain. I took the BCM out and opened it up to check for water didn't find any. I left it open overnight. I will put it back in tomorrow. I am going to get a new AC/Delco battery and install that. Will post results tomorrow.
Old Sep 20, 2018 | 11:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The wet carpet should be removed and dried. You should try to determine how the water entered that side. even though the BCM looked dry, it could have been wet and could have white deposits on the circuit board both sides). If it still has the issue after you remove the wet carpets. Check the board for corrosion.
Old Sep 21, 2018 | 03:12 PM
Corvette ED
I put the BCM back in the car and replaced the battery the car started up and all the lights were out and everything worked fine. Road tested and everything worked no lights on parked car. Two hours latter pressed fob it didn't unlock used key got in went to start car and it was like it was in VATS mode. Turn key and nothing. Disconnected the battery for 10 mins hooked it back up alarm was beeping got that stopped. Started the car and all lights on again and no comm message again in all systems. I wonder if theproblem has something to do with the VATS?
Old Sep 21, 2018 | 07:51 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CALL ME... PM Sent..
Bill
To All Service Lights On?
