Rear differential seals
When you have an Auto diff, there is a fluid divider bulkhead with a seal in it. It divides the diff lube from the trans and seals around the trans output shaft. ,The seal just POPS OUT, of the bulkhead just like the output shaft seals.
C5 differentials have very WEAK Belleview clutch pack springs.. TOO MANY C5 are driving around with worn out or broken springs. Its recommended that the springs are either inspected and or replaced. When they break, they will either wear out the clutch packs and or the broken pieces can destroy the spider gears.
