Anti-seize on O2 threads?
Old Sep 27, 2018 | 12:56 AM
striper's Avatar
striper
Default Anti-seize on O2 threads?
Title is my question. Opinions?
Old Sep 27, 2018 | 05:34 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Yes, just on the threads but that’s your decision !!
Old Sep 27, 2018 | 08:20 AM
feeder82's Avatar
feeder82
Use a electrically conductive brand of anti seize.
Old Sep 27, 2018 | 08:48 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The secret is NOT to use too much... All you need is enough to prevent the threads on the sensor and the threads in the collector bung not to seize. Most sensors come already coated with a dab of antiseize on the threads. If yours doesn't, just add a little.
Old Sep 27, 2018 | 08:58 AM
Kevova's Avatar
Kevova
If you remove the O2(s) for any reason you will want to reapply anti seize to the threads.
Old Sep 27, 2018 | 10:36 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
O2 sensor mfgrs say not to, but I suspect that's aimed at the folks who glob it on all over creation and it's running on the ground. Like Bill says, use very little. Make sure none can get globbed inside the exhaust where it'll contaminate the sensor.
Old Sep 28, 2018 | 10:37 PM
old stingray's Avatar
old stingray
I use a small amount,keeping it just on the threads.
Old Sep 30, 2018 | 03:45 PM
striper's Avatar
striper
I bought Bosch sensors. They come with a little dab on the threads. The last time I installed sensors I used a little. Has done nothing to make it any easier to get the sensors back out. Next question?
Old Sep 30, 2018 | 04:25 PM
StingrayRebel's Avatar
StingrayRebel
use just a little and what I like to do is use a paper towel and wipe it across the threads to get even coverage completely around the threads as well as cleaning off any excess
Old Sep 30, 2018 | 10:52 PM
TGstring's Avatar
TGstring
From: cruising between USA and Canada... SAVE THE WAVE!
every o2 sensor I've ever purchased has come with a single use copper based anti-seize. I'd use it because getting them off without any a few thousand miles down the road is a real beeach.
To Anti-seize on O2 threads?
