Electrical issue - car closes throttle/stalls
Old Oct 20, 2018 | 06:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Since something happened and made the fuel pump start operating just swap the fuel pump relay with the horn relay...that will kind of confirm if the relay is OK...next, see if you have system voltage KOEO at pin 87 (load side feed)...if good check for ground between pin 30 and a good ground...if no ground either bad ground at G104 or open in fuel pump windings...if good let’s jump pins 30 and 87...fuel pump should run continuously..if it runs OK now we might have problem on control side feed. For this we will use a 12 volt test light (if you use a multimeter you will see system voltage at all times instead of just for 2 seconds...that control feed circuit is power side switched and has a bias voltage when you remove the relay)...connect 12 volt test light to ground... touch tip of test light to pin 86...turn key on...test light comes on and goes out after 2 seconds...if good last step is to see if we have a good ground from pin 85 to ground...you can either check with multimeter or test light connected to battery positive...if ground bad the ground location is G105 at left lower engine block and the other end of the ground strap connects to right underneath the brake booster on the frame rail !!
Old Oct 20, 2018 | 06:55 PM
C5 Diag's Avatar
C5 Diag
Another quick thing I do is if I can’t connect with my scanner and thinking that the PCM might not be powered up is to check for a 5 volt reference on one of the sensors...I use the MAF...disconnect and see if you have 5 volts on the yellow wire with key on...if you have 5 volts the PCM is being powered !!
Old Nov 9, 2018 | 08:51 AM
Chameleon T/A's Avatar
Chameleon T/A
Just a quick update. Got a power probe tool and worked on the car last night. Finally found the problem, so I just gotta fix it this weekend hopefully! The PCM was not getting a good ground despite having previously checked all the grounds. They looked new (16k mile garage queen) but there's obviously a problem with one of them somewhere. Just need to track down which ground it is... Anyone know which grounds are tied to the PCM?
Old Nov 9, 2018 | 09:20 AM
C5 Diag's Avatar
C5 Diag
Did you get a PP 4 ??...pretty awesome tool but just be careful with that toggle switch !!...how did you determine that the PCM was not getting a good ground ??...G106 (above starter) is PCM ground...there are actually 3 or 4 wires at the PCM which are ground wires to G106...3 for MT and 4 for AT....on the BLUE PCM connector (C1) pin 1 and 40 are grounds...on the RED PCM connector (C2) pin 1 (Auto trans) and pin 40 are the grounds !!
Old Nov 9, 2018 | 10:39 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PCM ground is G-106 Passengers side of the engine above the starter on the side of the block.. Same connection as where the main battery ground connects to the block. Its a very small black/white stripe ground wire with a crimped on eyelet. Its going to be under the main battery ground lug.
Next to the battery on top of the chassis frame, will be G-104/108. The battery negative cable has two wires. One goes to the block and the other goes to that ground stud. Its an important ground as ALL the other chassis grounds get the battery neg source from that wire/stud ground. Make sure that it clean and tight.
Bill
Old Nov 9, 2018 | 10:42 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There is an identical ground on the OTHER side of the engine block G-105. There is another block ground wire on that ground point Also give that one a look and check to make sure that its clean and tight. There should also be a braded ground strap that goes from that ground to G-105 frame chassis ground.
Old Nov 9, 2018 | 10:46 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There is an identical ground on the OTHER side of the engine block (G-105). There is another small block ground wire on that ground point Also give that one a look and check to make sure that its clean and tight. There should also be a braded ground strap that goes from that block ground point to G-105 frame chassis ground. G-105 is a mirror image location as G-104/108.
Old Nov 9, 2018 | 12:02 PM
Chameleon T/A
Thanks for the info guys. I will be giving the grounds another good look over Tomorrow.
I determined the ground issue using the power probe. Touched the case of the pcm and saw .97v or something like that. Was pretty sure the pcm case should have been grounded internally to the harness, so i found that odd. i grabbed an alligator clip and hooked one end to the pcm case and the other end onto the ground stud under the battery on the frame rail. Checked with the probe again and it was down to around .30v. Alligator clip is very small, maybe 22ga or so.
  • Fired the car up and it idled great with no tach fluctuations for several minutes.
  • Disconnected the alligator clip and the car hiccuped and stalled a couple seconds later.
  • Reattached the alligator clip, fired it back up and ran great again for another few minutes.
  • Disconnected the alligator clip once again and i was able to make my way back to the drivers seat where the tach was bouncing around again. Rough idle also.
  • Reattached the alligator clip, smoothed out and no more erratic tach.
One other thing that caught my attention was the ign. switched voltage at the pcm was something like 9.8v or something like that. batt voltage at the time showed around 11.4v. This seemed like a fairly large split to me- 1.6v loss through the ign. switch/wiring/etc. But maybe that is normal? I have cleaned the contacts in the ignition switch per Bill's instructions.
Thoughts?
Old Nov 9, 2018 | 12:10 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its NOT normal and is an indication that you have a fair amount of voltage loss on one of the ignition switch contacts. Check that voltage when you CRANK the engine and I bet it goes out of spec low. If it does the PCM shuts down under low voltage cutoff until the voltage rises above the low voltage cut off level..
Old Nov 9, 2018 | 12:51 PM
C5 Diag's Avatar
C5 Diag
Thoughts?
Were these "voltage drops" checks done with the circuit "loaded"....i.e. "cranking the car" over in your case and then checking your voltages ??...if you did do this a 1 volt voltage drop on the ground side is WAY too high between battery negative (where the PP is hooked to) and the PCM... 0.1 volts is a better number...like mentioned before remove G106 and physically clean it...I use a small Dremel with a small wire brush. 1.6 voltage drop is way too high also...0.30 max is a good number for me...where did you get that 9.8v reading ??...at the PCM...or the PCM fuse 16 I believe ??
Old Nov 9, 2018 | 12:54 PM
C5 Diag's Avatar
C5 Diag
Sorry !!...LOL !!!...didn't read your post before I posted...you beat me to the punch !!...YES, circuit has to be LOADED for voltage drop checks to be accurate !!
Old Nov 9, 2018 | 01:33 PM
Chameleon T/A
The 9.8v reading was taken by backprobing the "ign. battery feed" pin #19 in the blue connector on the pcm with ign switch in the on position and engine not running. I am going to recheck that pin again tomorrow to verify that reading was correct.
The ~1v reading on the pcm case was during the same "on" state. If the pcm was properly grounded, it should have shown zero volts on the case but wasnt so...
Old Nov 9, 2018 | 02:27 PM
  #33
gimp's Avatar
gimp
Looks like you're on the right track! Keep us updated please.
Old Nov 9, 2018 | 02:47 PM
  #34
C5 Diag's Avatar
C5 Diag
Oh, OK so you backprobed pin 19....well with the Power Probe connected check pin 19 voltage while cranking...you'd be checking everything from battery positive to the pin 19...see what the voltage drop is....then check the ground side while cranking to the PCM case and also at G106 !!...well, at least it ran with the PCM given an external ground with the Power Probe...I'd suggest getting the Power Probe 5 volt adapter tip for simulating a 5 volt ref. for testing purposes. Keep us updated tomorrow !!
P.S. I'll be fiddling with my car tomorrow so if you want to compare something let me know !!
Old Dec 8, 2018 | 11:54 AM
  #35
Chameleon T/A
Finally getting around to an update... Someone who installed the motor in the car (previous owner) added a PCM ground location on the back of the passenger side cylinder head. It was loose! So those issues are now gone and I'm back to the Code C1232. I'm making a new thread since it's an unrelated issue to what this thread was about:
https://www.corvetteforum.com/forums...859-c1232.html
Thanks for all the help!
