High pitched whine
Old Oct 12, 2018 | 03:32 PM
e009061's Avatar
e009061
1st Gear
Default High pitched whine
C5 with 6500 miles. I hear a high pitched whine while the car is running obviously. Sounds like the pitch changes when i hit the brakes . weird, sounds like it could be the fuel pump but i don't know. Has anyone had the same issue?
Old Oct 12, 2018 | 04:09 PM
3sACROWD's Avatar
3sACROWD
Where is the high pitch whine coming from? The fuel pump is located in the tank behind the driver's seat. I persinally wouldn't classify it as a high pitch whine though. The fuel pump sound will often fluctuate while at idle and you activate a turn signal.
