fast 92mm intake
Old Oct 31, 2018 | 03:03 PM
JBoyle997's Avatar
JBoyle997
Default fast 92mm intake
Installing (or trying to install) the fast 92mm on my c5z06 during the cam and heads build. Need the MAP relocation kit and apparently this part is not made anymore. Is there a different way to go about this?
Old Nov 1, 2018 | 02:54 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
You can run the map the sensor in the back in the factory location on a FAST 90 or 92
Old Nov 1, 2018 | 03:29 PM
StingrayRebel's Avatar
StingrayRebel
if you need to extend wires you can cut the map connector off a few inches back and add whatever length of wire you need to avoid using an extension harness
Old Nov 2, 2018 | 09:54 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You sure that you can find that relocation kit. Have you checked ZIP Corvette, or Ecklers Corvette??
Old Nov 2, 2018 | 10:00 AM
tbrowne's Avatar
tbrowne
Try this link - it might help. Post #9 shows how mine was modified to fit.
https://www.corvetteforum.com/forums...-firewall.html
Old Nov 3, 2018 | 08:33 AM
JBoyle997's Avatar
JBoyle997
Thanks for all this great info guys, I will continue to try to figure this out and keep you posted.
Old Nov 3, 2018 | 08:37 AM
JBoyle997's Avatar
JBoyle997
Tried them all, they say its discontinued
Old Nov 3, 2018 | 08:40 AM
JBoyle997's Avatar
JBoyle997
Ok great. So in this 9th post the intake is being modified without the relocation kit?
Old Nov 3, 2018 | 10:36 AM
Cutlassmaster's Avatar
Cutlassmaster
When I did my FAST 90 I just used a screw in brass nipple and a tap set. A little RTV when assembling and it worked great. I added a rubber hose and just placed the MAP sensor next to fuel rail at the back of intake. No issues, extensions or anything else to modify.
Chris
Old Nov 3, 2018 | 11:02 PM
tbrowne's Avatar
tbrowne
As shown in Post #9 in my previous response - the intake was modified and it fit without the relocation kit. Your's should also fit without the need for a relocation kit.
To fast 92mm intake
