Where to get replacement alternator
Old Nov 6, 2018 | 10:16 AM
DaBoogie42's Avatar
DaBoogie42
Cruising
Default Where to get replacement alternator
I know there are alot of threads on alternators and I've read the sticky but I still have a few questions. I have a 2000 C5, with 1000 watt amp. I bought the car used and the dealer put in new alternator and battery. However the alternator is a PepBoys 140 amp and I'm getting the faulty charge DIC. So my questions are.
1. where do a get an OEM replacement 10246634. I have seen on DB electronics and Rareelectric. Anyone have these?
2. would the 110 be enough for the amp?
3. i have seen a couple on ebay, is it worth buying used and rebuilding?
4. does the 10131682 work, i see some saying it does others say no. Sounds like the only difference is the decoupler.
Thanks in advance.
Old Nov 6, 2018 | 12:04 PM
Velocity_Vette's Avatar
Velocity_Vette
I would check with a Corvette-leaning GM parts supplier like Cultrag Performance first.
Old Nov 6, 2018 | 12:05 PM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
nearest junkyard has plenty
Old Nov 6, 2018 | 02:18 PM
JHrinsin's Avatar
JHrinsin
more alternator info here;
https://www.corvetteforum.com/forums...a-97-03-a.html
Old Nov 8, 2018 | 03:54 PM
bc6152's Avatar
bc6152
Thanks in advance.
Check with www.contemporarycorvette.com a Corvette salvage yard with many Corvette alternators...
Old Nov 8, 2018 | 08:20 PM
Ed Ramberger's Avatar
Ed Ramberger
These are the numbers for the regulators.
Old Nov 8, 2018 | 08:57 PM
GCG's Avatar
GCG
( ^^^ that post looks familiar ).
Let me give him access to the links:
If you are going to take the rebuilt route, take a look at this post. It has info on the right regulators for both, 97-01 and 02-04. The price is around $30.
This other post has detailed info on the rebuild procedure and links to get the other parts.
To Where to get replacement alternator
