Injectors
Old Nov 25, 2018 | 02:15 AM
Luis Vazquez's Avatar
Luis Vazquez
Cruising
Default Injectors
Have a 97 A4 ls1 h/c currently on stock injectors @ 90% duty cycle, will be swapping over to a Texas speed ms4 & run some nitrous down the road so will be looking at anywhere from 500-600 hp. What injectors does anyone recommend & what results have you seen?
Old Nov 26, 2018 | 02:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Luis.... I would discuss this with your tuner. You will have to have the higher flow rate injectors properly tuned to the PCM. MAKE SURE that what ever injectors that you purchase, they come with flow data sheets so the tuner can properly tune them into the PCM.
I have a heads, cam, heads & Fast 90 LS6 making 450 RWHP and 42 lb/hr work excellent. I would guess that 60 lb/hr would be needed to get close to 600 RWHP. NOTE!! You will need a BIG UP-GRADE to your fuel system to get that flow support!!!
