Change to 18” tires
Old Dec 5, 2018 | 02:15 PM
VETTEC599's Avatar
VETTEC599
Default Change to 18” tires
Since I need new tires -I am thinking of changing to 18” tires both front and rear. To avoid any problems what are the best wheel and tire sizes (both new) to avoid any problems - fault codes? What wheel width and offset? What about tire sizes? Any suggestions appreciated.
Old Dec 5, 2018 | 03:34 PM
jumpmanmb87's Avatar
jumpmanmb87
To properly avoid this you should take some pride in car ownership and actually search for the questions you seek. I pulled all these less then 10seconds, try harder next time.
https://www.corvetteforum.com/forums...are-setup.html
https://www.corvetteforum.com/forums...n-advance.html
https://www.corvetteforum.com/forums...size-help.html
https://www.corvetteforum.com/forums...questions.html
https://www.corvetteforum.com/forums...ll-around.html
Old Dec 5, 2018 | 11:58 PM
grantv's Avatar
grantv
Without flares, seems one of the more popular combos is 265 or 275-35-18 and 295 or 305-35-18
Wheel widths 9.5 to 10 and 10.5 to 11
Unsure on offsets, sorry
Old Dec 6, 2018 | 09:06 AM
Gordy M's Avatar
Gordy M
For tires sizes, look at the tire diameters, you want the back tires to be 1/2" or more larger than the front. Sizes depends on the wheels widths, offsets should be very close to the current offsets for C5 Corvette, whether you keep with the base model or Z06, look at the offset of stock wheels and buy accordingly. Wheels are a personal taste, look at the various offerings, e.g. ebay, and find someone who is reputable to buy from. the wider the wheel and tire the higher the price.
To Change to 18” tires
