Help
Old Dec 15, 2018 | 12:38 PM
Dilligaf1's Avatar
Dilligaf1
Navigator
Default Help
Completely baffled have my car up on jack stands emergency brake on in 1st gear workin on front end an car just started cranking over pulled right off stands and dragged it a few before I could get it in neutral. Kept cranking till I disconnected the battery an starts every time try to hook battery up WOW any ideas why ?
Old Dec 15, 2018 | 01:12 PM
KOZ's Avatar
KOZ
What are you working on?
Old Dec 15, 2018 | 01:27 PM
Dilligaf1's Avatar
Dilligaf1
Navigator
03 z06 I was workin on the front number an front ground effects. Didn’t touch the engine bay
Old Dec 15, 2018 | 01:33 PM
Dilligaf1's Avatar
Dilligaf1
Navigator
Before I got batt disconnected put key in car started up. Turned key off car shut off but starter kept cranking
Old Dec 15, 2018 | 02:57 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Starter solenoid stuck?
Old Dec 15, 2018 | 03:26 PM
mmartinez's Avatar
mmartinez
Starter solenoid stuck or could be welded contacts on Theft Deterrent Relay located in passenger footwell area above BCM, or a short in the wiring suppling 12 volts all the time to the TDR relay coil.
Old Dec 15, 2018 | 05:04 PM
Dilligaf1's Avatar
Dilligaf1
Navigator
I’m guessing selonoid stuck but never heard of 1 just engage like that. Key to car was in the house.had car for 18 months an no problems. If it happens again I’ll have to investigate more. Thanks again
To Help
