knock sensors
Old Dec 23, 2018 | 10:58 PM
aahrested's Avatar
aahrested
Default knock sensors
I have a 1998 C5, A4, and just bought an LS3 crate engine for it. I am trying to get everything together before I make the swap. I ordered several harnesses from Summit, and one that I received was an extension harness for the knock sensors. This harness will plug into the the connections already installed on each side of the block. Originally I thought this was great, as it plugged right in for a neat installation. But, I have recently read that the computer may not read the signal properly, and I should instead install original style knock sensors (the type which were installed in the valley) on the sides of the block. Anybody with any information about this would be appreciated.
Old Dec 26, 2018 | 03:12 AM
Vette97sc's Avatar
Vette97sc
You have to use original knock sensor. So you have to drill and make new threads side of block.
https://www.google.com/search?q=ls1+...Weta_-Y6MPbU2M
Old Dec 26, 2018 | 08:32 AM
69's Avatar
69
Cruise-In VI Veteran
Great read here
Getting a Modern LS3 into Your C5 is Easier Than You Think
http://www.superchevy.com/how-to/engines-drivetrain/1603-getting-a-modern-ls3-into-your-c5-is-easier-than-you-think/
cheers,
GOOSE
Old Dec 26, 2018 | 10:22 AM
bigsapper's Avatar
bigsapper
So drill and tap existing LS3 location for LS1 sensors, or...
Originally Posted by 69
Great read here
http://www.superchevy.com/how-to/eng...han-you-think/
cheers,
GOOSE
Screw the LS1 sensors into an alternate, existing boss.
Does it make a difference? Is one versus the other the root of the KR issue?
Old Dec 30, 2018 | 12:11 PM
aahrested's Avatar
aahrested
As it turns out, I can use the Casper harness using plugs already installed on the LS3 crate engine. As long as the tuner is aware, those sensors will work fine. There is no need to drill and tap anything. A tech from "Injection Connection" out of Georgia, who has done about 40+ of these conversions, recommended that I just turn them off completely. His position is that they are way too sensitive, and driving with a lap top will show that every pot hole, or suspension bump triggers a retard in timing.
Old Dec 30, 2018 | 04:06 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
As a last resort most all tuners can adjust the "knock sensor" tables in your existing ECM tune--
Whether they need to be "sensitized" OR "de sensitized" This depends if the tuner hears real knock or is getting false knock
Old Dec 30, 2018 | 04:35 PM
StingrayRebel's Avatar
StingrayRebel
personally I wouldn't want to have them turned off on my car... if you don't have enough octane and/or your tune is on the edge and something goes wrong then you will be buying another ls3 lol
Old Dec 31, 2018 | 09:25 AM
bigsapper's Avatar
bigsapper
E85 is the answer you seek. lol
Old Dec 31, 2018 | 03:40 PM
tblu92's Avatar
tblu92
Sensitizing OR de sensitizing the knock tables does NOT turn them OFF----It changes the frequencies where the sensors pick up detonation-------------------------
I agree about not turning them OFF as well ---Best only done on a race only application using race fuel all the time--
To knock sensors
