Blackwing instal HELP!!
Old Oct 30, 2002 | 02:24 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Default Blackwing instal HELP!!
I can't get the Blackwing to "seat" on the 4 rubber grommets. I have not tightened everthing, but it appears the large, black plastic shroud is forcing the blackwing "up", preventing it from seating on the grommets.
HELP PLEASE!!
Old Oct 30, 2002 | 02:26 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Blackwing instal HELP!! (98BlackMagic)
PUSH LIKE HE!!.. :D ...seriously they are tight but they will go on
Old Oct 30, 2002 | 02:43 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Default Re: Blackwing instal HELP!! (pewter99)
Man, I'm pressing just as hard as I can, but they still won't seat. :cry . Maybe it's the cld weather...only about 45 degrees out. Thinking about hooking up the wires and running it a bit to get it nice and warm in there and then push like heck.
Old Oct 30, 2002 | 03:06 PM
pewter99's Avatar
pewter99
maybe a little lube...silicon spray maybe...only thing is then you pick some dirt...I am sure the cold weather isn't helping
Old Oct 30, 2002 | 03:15 PM
jlfrogy's Avatar
jlfrogy
Dish soap will do the trick. If I could put the thing on anybody can.
Old Oct 30, 2002 | 03:17 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Thanks Pewter99. They're close, but just can't get them to seat (well, I did get one to seat on the Blackwing). I don't think it's going to hurt leaving them like this for a while, do you? Everything in there seems so tight now, that I can't imagine it going anywhere.
Thanks and :cheers:
Old Oct 30, 2002 | 03:23 PM
pewter99's Avatar
pewter99
It isn't going anywhere..I drove with mine loose for a long time...I took it off and just didn't reattach it for awhile.
Old Oct 30, 2002 | 03:38 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Thanks again. I just drove it to make sure everything was intact, which it was, so I believe you're correct. I'll wrestle with it later.
Don't know if it's my imagination or not, but it sure does seem to make a difference in response. Even the Borla Stingers sound better :eek: . Probably just my imagination getting the best of me.
Old Oct 30, 2002 | 05:54 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Love that SOTP response!
As far as the Blackwing, you certainly don't have to worry about it running off anywhere. What I finally had to do was loosen the hose clamps on each end of the Blackwing while it was installed and then work the unit down flush on top of the radiator cap. Once it sat well, I tightened up the hose clamps again.
Good Luck!
Old Oct 30, 2002 | 06:10 PM
KerryH's Avatar
KerryH
Default Re: Blackwing instal HELP!! (C5 StockSwap)
Hey, I'd watch the pushing like hell thing, I did that to mine and broke one side of the black wing mounts off. It's that fine line between pushing to hard and not enough. Good luck.
Old Oct 30, 2002 | 06:48 PM
aces's Avatar
aces
Default Re: Blackwing instal HELP!! (KerryH)
lube everything including the hose ends
Old Oct 30, 2002 | 07:06 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: Blackwing instal HELP!! (aces)
I pulled the plastic pins out of the center of the fastners, put the grommets in the blackwing, pushed the fastners (which are inserted into the grommets) down through the shroud holes, then I put the pins back into the center of the fastners....worked great!!
Old Nov 2, 2002 | 12:33 AM
lostsoulny's Avatar
lostsoulny
Good Luck!
losen it and then try to seat them then retighten, also warmer day couldn't hurt. It wont go anywhere either way, worst case the airbridge will rub against the hood liner.
Old Nov 2, 2002 | 01:42 AM
AZGASSER's Avatar
AZGASSER
I installed mine in 90+degree weather and worked like heck to get the two gromets over the radiator shroud to seat right. I left all the hose clamps loose and was only able to get the two on the filter to sit on the mounting brackets. Maybe it is the adapter for the 01-03 that is causing it. I have had mine on for about 1200 miles and not one problem. Knock on wood! Good luck! :seeya
Old Nov 2, 2002 | 02:05 AM
DsC5's Avatar
DsC5
Default Re: Blackwing instal HELP!! (AZGASSER)
except it wasn't 90 degrees. :seeya
Old Nov 2, 2002 | 12:54 PM
buzzme's Avatar
buzzme
Default Re: Blackwing instal HELP!! (DsC5)
Make sure that the ducts on both sides of the MAF sensor are fully seated as well as the end of the duct that goes into the blackwing. If they arn't fully seated, it will stop the blackwing from aligning with the grommet holes.
Old Nov 2, 2002 | 01:25 PM
alc2001's Avatar
alc2001
I had the same experience as you and most others installing the Blackwing. I loosened all the clamps and was able to finally work the air bridge gromettes into place.
To Blackwing instal HELP!!
Old Nov 2, 2002 | 02:04 PM
anniv88's Avatar
anniv88
I had the same problem with my 01. I finally removed the whole
assembly, loosened all the clamps, and forced everything together
as tight as I could get it. It was still tight but I was able to get the
gromets over all 4 studs.
Life is good when your car can breathe.
Old Nov 2, 2002 | 03:35 PM
rrobert22's Avatar
rrobert22
Default Re: Blackwing instal HELP!! (anniv88)
Keep the clamps loose while you work with it, mine never did seat down all the way but close enough. Also make sure there are not any wires under it. If not seated down far enough it will rub the hoodliner and look funny. good luck :cheers:
Old Nov 3, 2002 | 01:10 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Default Re: Blackwing instal HELP!! (rrobert22)
Thanks for all the responses, guys! I think the weather is/was a factor in installing, but man does it seem to make a difference in SOTP! :eek:
I'll leave the few grommets loose for now and hope for some warmer weather here in St. Louis :cry .
