2004 C5 Z51 4L60-E roadster!!
Just sitting in the garage with the key in my pocket, the CD changer starts cycling back and forth.......making noise. I thought there was a racoon under the car or something.
I wonder if I remove the $600 piece of junk.................is there anything that could be installed using the same harness??
Try remocing plug at the changer and reinserting it
Sometimes just unplugging the connector at the bottom rear of the changer and letting it go thru the reset process loading all 12 CDs will get the changer working normally. Do this with the radio OFF.
Sometimes just unplugging the connector at the bottom rear of the changer, reinserting it and letting it go thru the reset process loading all 12 CDs will get the changer working normally. Do this with the radio OFF.
