Inconsistent Headlight Retract
Old Feb 28, 2019 | 07:01 PM
Zoidman's Avatar
Zoidman
Default Inconsistent Headlight Retract
Hey Guys!
I just upgraded my headlights to new LED bulbs. They look great, except now for some reason the headlights do not always flip down when I turn the lights off! The behavior is not consistent.
Sometimes the headlights flip down like they should, other times they do not.
I noticed that when I flip the switch off for the headlamps, the light bulbs get a small flicker illumination while attempting to flip down.
Help!
Thanks!
Old Feb 28, 2019 | 08:31 PM
robmiz's Avatar
robmiz
Try the hi beam position, that how I lower them on mine.
Old Feb 28, 2019 | 10:21 PM
STRMLNE's Avatar
STRMLNE
^^ I’ve heard about this glitch too. Apparently if the high beam is on they work fine.
Old Mar 4, 2019 | 10:48 AM
Zoidman's Avatar
Zoidman
This isn't really the solution I'm looking for, it defeats the point of my upgrading the low beams if I just leave the high beams on all the time...
I think there may be something wrong with the lights I got, and maybe need to return for a different set.
Old Mar 4, 2019 | 11:18 AM
Tsumi's Avatar
Tsumi
Many threads on this issue. The reason is because LEDs do not behave like halogen bulbs in a circuit.
When the lights are turned off, the HCM "on" pin becomes grounded through the headlights. It is looking for either a maximum resistance or certain voltage before it drops the headlights. If the voltage/resistance is too high, which can be the case with LED bulbs due to how they behave at low voltages, the HCM thinks a bulb is out and keeps the headlights up. The remedy is typically having resistors in parallel with the bulbs, but that generates a lot of heat. One person has reported success with anti-flicker capacitors, but haven't heard back from others that said they would try it. Capacitors would be preferable to resistors in that they won't consume power like resistors.
Old Mar 4, 2019 | 01:26 PM
STRMLNE's Avatar
STRMLNE
you don’t have to high beams on all the time. You just have to turn them on in order to close the lights. I’ve heard of this problem which is why I kept the stock halogen. As stated above I don’t think anyone has reported a permanent solution.
Old Mar 4, 2019 | 02:02 PM
Tsumi's Avatar
Tsumi
I have a permanent solution, except it requires hacking up the HCM harness which most people aren't willing to do.
Old Mar 4, 2019 | 08:07 PM
Zoidman's Avatar
Zoidman
This is annoying... I thought it would be a plug and play solution.
I'm not a stranger to hacking harnesses, but it doesn't seem like I would need to do that if there are easy solutions out there?
Something like this seems to fit the bill, no splicing needed.
Amazon Amazon
I'm not a big fan of such a large resistor, the heat it must generate must be immense.
I found this plug and play capacitor harness
Amazon Amazon
I'm a little concerned with it though because one of the reviewers reported it didn't help his LED light conversion for his C4. I don't know the detailed difference between C4 and C5 lights, but they are likely not that different
Old Mar 4, 2019 | 08:13 PM
Tsumi's Avatar
Tsumi
LEDs by their nature become an open circuit when voltage drops to a certain level. If the HCM doesn't detect low enough resistance/volts, it's not going to lower the lights. The capacitors might fool the HCM, it might not, YMMV. One member said it did on his C5. No other member reported success or failure.
Alternatively, you can get rid of the OEM HCM and build your own HCM that will close on demand. UM Rebel (I think) has a detailed writeup on how to do so.
Old Mar 4, 2019 | 08:46 PM
Zoidman's Avatar
Zoidman
LED's generally become closed circuits, limiting the flow of current, once the voltage falls below the activation voltage of the diode. If the voltage is above the diodes activation voltage they allow current to flow through them, in this case emitting light as a by product.
https://www3.nd.edu/~lemmon/courses/...ab1/node6.html
I'm not sure if the capacitors make sense to fix this situation. Capacitors sort of work like a mini battery continue to provide power to the LED's for a very brief amount of time until the capacitor is depleted. This is great when you have dirty power delivery to LED's because it can debounce the power spikes or dips providing a smoother output to the LED's thus eliminating flickering as advertised. I don't think it would change much of the electrical characteristics from the HCM point of view though.
Old Mar 4, 2019 | 09:14 PM
grantorino's Avatar
grantorino
LED's have low resistance not high. Adding resistors ups the load on the circuit allowing the command to close to function. There's nothing wrong with your LED bulbs. Just simply add resistors or as stated above, turn on your high beams ( more lights on, more resistance) to lower them when you shut the car off.
Old Mar 4, 2019 | 09:21 PM
Tsumi's Avatar
Tsumi
No one knows exactly how the HCM operates and senses things. It may be that the capacitor fools the HCM into thinking that there is low enough resistance by absorbing some of the current that would otherwise be blocked by the LED. Who knows, as only one person has reported success while no one else has confirmed or denied that it worked.
Technically, LEDs have no resistance, and actually have a voltage drop. The current going through the LEDs is controlled by resistors or a driver. If the voltage drops below the voltage drop threshold, the LED acts like an open circuit (infinite resistance) because it can't push past the drop, and that's where it plays havoc with the HCM.
Putting resistors (and additional bulbs) in parallel with the bulb does not increase overall resistance, it decreases it. The HCM is looking for low resistance (or low voltage), not high resistance.
Old Apr 20, 2019 | 07:27 PM
Zoidman's Avatar
Zoidman
I ordered the capacitor kit and can report that it did not fix the problem. As a matter of fact, once installed the headlights did not turn on at all.
The resistor kit on the other hand did solve the headlight problems, and they now pop up and down correctly.
Unfortunately, while doing all this my IPC lights are now out... The warning indicators come up, but there is no back-lighting. Is this somehow related to installing the LED headlamps? Could this have fried the multi-function light switch stalk?
Old Apr 20, 2019 | 07:29 PM
Tsumi's Avatar
Tsumi
I don't see how it could have, as the instrument cluster and headlights are on different circuits.
Thanks for confirming the capacitors don't work. I hate using resistors as a bandaid.
Old Apr 20, 2019 | 08:20 PM
Zoidman's Avatar
Zoidman
A lot of people report problems with the IPC lights and the turn signal stock, which is also used to turn on/off the headlights
https://www.corvetteforum.com/forums...-a-how-to.html
Old Apr 20, 2019 | 08:31 PM
STRMLNE's Avatar
STRMLNE
That sucks. I’d go back to stock lights.
Old May 12, 2019 | 07:59 PM
Dave's 1st Corvette's Avatar
Dave's 1st Corvette
Hello did you use these resistors that you described earlier?
Amazon Amazon
Because I just bought these and sadly must report that the headlight doors do not naturally close with these installed:
Amazon Amazon
If you are reporting success with the O-NEX brand of resistors, then I will return mine and purchase those, and in the mean time, activate the high beams in order to close the headlight doors.
To Inconsistent Headlight Retract
Old May 13, 2019 | 10:31 AM
Zoidman's Avatar
Zoidman
Yup, I bought the O-NEX 50w in-line resistors. They worked perfect for me
Old May 13, 2019 | 06:13 PM
Dave's 1st Corvette
Thank you Zoidman I will order the same ones and report back to the forum in a week or so.
Old May 13, 2019 | 06:52 PM
STRMLNE's Avatar
STRMLNE
Looks like this thread the resistors didn’t work.
https://www.corvetteforum.com/forums...ose-doors.html
