C5 oil temp cause
Old Mar 8, 2019 | 09:03 AM
RKWatson's Avatar
RKWatson
4th Gear
Default C5 oil temp cause
I get low oil temp under gauges. What might caus this
Old Mar 8, 2019 | 09:16 AM
MikeyMcFly's Avatar
MikeyMcFly
Some light reading here.
Old Mar 9, 2019 | 12:19 AM
Moved to C5 Tech.
Old Mar 9, 2019 | 12:58 AM
BigGun's Avatar
BigGun
What is the oil temp on the display?
Old Mar 9, 2019 | 10:06 AM
RKWatson's Avatar
RKWatson
4th Gear
Default C5 oil temp
Reads "oil temp low"
Old Mar 9, 2019 | 10:24 PM
BigGun's Avatar
BigGun
If you use the dic and cycle thru the gauges section one of them will be oil temp. What is the temp?
Old Mar 10, 2019 | 02:52 PM
RKWatson's Avatar
RKWatson
4th Gear
"oil temp low"
Old Mar 10, 2019 | 09:40 PM
foggy's Avatar
foggy
There is an OIL TEMP SENDING UNIT over/by the oil filter..
It is bad.. or the wiring/ plug...
Pretty simple fix.. Just be patient and use your tools wisely.. Kind of PITA to contort your hands...
Mine started giving really weird readings on the DIC.. Like 30^ below current ambient temps !!
Old Mar 11, 2019 | 08:44 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
"oil temp low"
Believe it or not, we're trying to help you! If you scroll through the DIC, you should get an actual number, telling you the oil temperature. What is that number?
FWIW, most cars that have an actual oil temp read out, show an oil temp of 200-205*F, after the car/truck is fully warmed up. This is what my 'Vette shows, HOWEVER, it takes a LONG time for it to get there. THAT is why we're asking you for a number.....
Old Mar 11, 2019 | 10:31 AM
RKWatson's Avatar
RKWatson
4th Gear
Mine never comes up with a number - just "low oil temp". Even after I have driven and EJW is 207 to 210 deg. I plan to try a new sensor.
Old Mar 11, 2019 | 03:34 PM
Cutlassmaster's Avatar
Cutlassmaster
Guys, the DIC can and will say low oil temp. So please stop asking because he has answered multiple times. It sounds like it is the sensor. You could buy a new one and ohm each one to compare them before swapping it. I have seen my car say low oil temp multiple times when it was below 30 F outside.
To C5 oil temp cause
