c5 cranks, wont start
Old Mar 9, 2019 | 11:32 AM
dfactor1's Avatar
dfactor1
1st Gear
Default c5 cranks, wont start
just getting my 1999 back on the road after 4 years of sitting in my garage. new battery. cranks good, wont start. any ideas as to where to begin?
Old Mar 9, 2019 | 01:38 PM
rkj427's Avatar
rkj427
Pro Mechanic
Welcome to the forum.
You posted in the "introductory" area, and you would have better opportunities for responses if you posted this question in the C5 Tech area, link below.
https://www.corvetteforum.com/forums/c5-tech-1/
Old Mar 9, 2019 | 03:26 PM
Moving this over to the C5 Tech section.
Old Mar 9, 2019 | 04:02 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you didn’t use any type of gas stabilizer before storage it’s a pretty good bet your injectors are clogged and maybe mechanically “stuck closed”...I’d first listen if you can hear the fuel pump prime for 2 seconds after turning the key on and then tap on each injector while starting...you may have to get those injectors cleaned if varnished up...to make sure it’s a “fuel delivery” issue you can spray some brake kleen or starter fluid into the brake booster or PCV and then try to start...if you are getting spark the car will start or attempt to start !!...also be a good idea to throw some BG 44K or Techron in your tank !!
Old Mar 11, 2019 | 01:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Read and post your DTCs also... Post up what you see..
BC
To c5 cranks, wont start
