Clutch feel changes after hard acceleration
Old Mar 19, 2019 | 06:25 PM
STRMLNE's Avatar
STRMLNE
Default Clutch feel changes after hard acceleration
Stock car has an oem replacement clutch that is about 25k miles old. (Total car miles 60k. Decided to put a new clutch in bc of convenience that the rear end was taken apart for a diff leak.)
if i accelerate hard after completely disengaging the clutch the next time I put the clutch in the clutch “feel” changes. Not every time. But about 50%. It’s much more sensitive. Clutch “feel” becomes much closer to the floor board than before. Then the issue completely goes away. If i don’t drive too hard there are no problems. (Clutch fluid is new and clear).
Im thinking throw out bearing or master slave. Any way I can diagnose or narrow what is the problem?
Thank you.
Old Mar 20, 2019 | 01:02 PM
turabo87's Avatar
turabo87
Welcome to the club. Common issue with OEM clutch hardware. You're boiling the clutch fluid hence losing fluid pressure and feel. Do you have power mods on the car? It's worse as you make more power and heat. There's also tons of threads on this.
Old Mar 20, 2019 | 01:50 PM
StingrayRebel's Avatar
StingrayRebel
I agree that it's oem and oem style clutches that cause the issue but my opinion is the pressure plate causing the problems and not heat... at one point I believed it could be heat but I tried very expensive fluid with a high boiling point and also rerouted and wrapped the clutch line along with a tick master cylinder, none of which worked... after all that there is no way the clutch fluid could get that hot that fast from just a pull to redline in one gear... sounds like you might be in for another clutch if you really want to fix it, this is why I always recommend a quality aftermarket unit instead of an oem replacement
Old Mar 20, 2019 | 02:09 PM
STRMLNE's Avatar
STRMLNE
Car is completely stock. Clutch fluid is DOT 4. Problem only recently started happening. Never had the issue in the past and I’m in AZ. I guess I’ll keep an eye on the clutch. Doesn’t slip at all, etc. I’ll go with an after market next time I need it changed.
Old Mar 20, 2019 | 03:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You replaced the CLUTCH but,,,,,,,,,,,,,,,,,, Did you replace the master cylinder???????????????
If I were in your shoes,, I would change the Master Cylinder and see if that has any resolve on the problem. They get clogged up with nasty clutch dust slime and loose volume, leak and act al wonky. Easy repair and HEY, it may just fix the issue.. Not expensive either.
Bill
Old Mar 20, 2019 | 03:24 PM
STRMLNE's Avatar
STRMLNE
Master cylinder is original, never been replaced. That’s what I was thinking. I’ll start there. Thank you!
Old Mar 21, 2019 | 10:34 AM
Bushman66's Avatar
Bushman66
Thank you.
My 2004Z clutch "feel" changes as well, only on that first clutch push after a run at *cough* (slightly haha) elevated speed *cough*. Mine doesn't seem to change the pedal engagement position, more that it just feels different.
I don't worry about it, since the clutch runs fine at all other times, and it hasn't caused any issues. I have done the ranger method to swap out the clutch fluid, may do that a few more times, right now, the clutch fluid seems to be staying pretty clean, but it was nasty when I changed it out (45K miles, pretty sure it had never been swapped).
Old Mar 21, 2019 | 02:22 PM
My Vette Life's Avatar
My Vette Life
Agree with boiling the clutch fluid. I get that all the time with m hard driving
Old Mar 21, 2019 | 05:05 PM
Leftlane_1's Avatar
Leftlane_1
same here. I try not to shift past 5k rpm
Old Mar 21, 2019 | 05:24 PM
STRMLNE's Avatar
STRMLNE
man, that’s crazy. My outside temp is 65, car temp 190, DOT 4 clutch fluid good to 510, and it’s boiling? That’s crazy if it’s true.
Old Mar 21, 2019 | 05:39 PM
StingrayRebel
man, that must suck
Old Mar 21, 2019 | 05:42 PM
Leftlane_1's Avatar
Leftlane_1
man, that must suck
yep, ive shifted from 3rd to 4th before at 6K and the pedal was stuck to the floor and couldnt even get the shifter to go in gear. gave me a fright for a minute while cruising at 100+ mph in the far left lane with no ability to shift.
just had to keep messing with the pedal to get it to come back up, then started pumping it until i could re-engage a gear.
acroy's Avatar
acroy
Same suggestions here - Most likely the clutch hydraulics, not the clutch itself. Invest in good quality MC, Slave, and bleeder - stock clutch will last a long time at stock power levels with reasonable use.
Old Mar 21, 2019 | 07:03 PM
My Vette Life
yep, ive ****** from 3rd to 4th before at 6K and the pedal was stuck to the floor and couldnt even get the shifter to go in gear. gave me a fright for a minute while cruising at 100+ mph in the far left lane with no ability to shift.
I never had that problem, only had the hard pedal feeling.
Sucks if your pedal drops and thats a horrible feeling i would imagine
Old Mar 21, 2019 | 07:10 PM
STRMLNE's Avatar
STRMLNE
I’ve been using the turkey baster method of changing clutch fluid. Is there any substantive benefit to using the bleeder or is it just a time saver? (A remote bleeder was installed on the clutch swap)
Old Mar 21, 2019 | 09:32 PM
crf450x's Avatar
crf450x
What exactly is going on with the hydraulics when this happens? Why would a master or slave cylinder care how fast the clutch is spinning?
To Clutch feel changes after hard acceleration
