Rad Fans
Old Mar 19, 2019 | 08:22 PM
openpot1's Avatar
openpot1
Default Rad Fans
What does it take to replace the radiator fans. Mine are 15 years old and awful loud.
Old Mar 20, 2019 | 10:32 AM
Robrote's Avatar
Robrote
I replaced a motor in one of mine. It's a fairly straight forward swap once you remove the fans. The fans are a PIA to wiggle out, but a little tugging in the right places will do the trick. They come out as a unit, both fans and plastic rad cover. The fan motor was aroud 50 bucks. That being said, the factory fans are not quiet in comparison to todays fans.
Old Mar 20, 2019 | 04:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have you ever CLEANED the 1" space between the actual radiator and the AC Condenser. Just remove the air bridge and them the plastic cover over the radiator and you will be able to see the space. Use a garden hose and spray the radiator from the engine compartment. You will be AMAZED at what comes out! Sand, Dirt, grass ect………..
I bet you its full of crap and the fans are struggling to pass air (thus noisy) I would try that before you invest a lot of cash on parts.
If you have a STOCK C5, the OEM fans do a good job for the most part. If you modd the engine, sometimes it require cooling system improvements..
Bill
Old Mar 20, 2019 | 04:45 PM
STRMLNE's Avatar
STRMLNE
Anything ya’ll would recommend to deal with squeaky fans? When mine are running and I turn off the motor they squeek like crazy until they stop spinning. I’m hesitant to just start spraying wd40 down there.
Old Mar 20, 2019 | 05:24 PM
gimp's Avatar
gimp
Take them out and clean them, that's step 1. While doing so, make sure they rotate happily, no grind or shudder or shake to tell you the bearings are bad.
I personally have not heard of the stock fans failing at this age due to bearing issues, though I am sure it is possible.
PS, if you want an awesome upgrade, the DeWitts SPAL setup is excellent. It's loud (like, at idle, louder than my exhaust) and sounds like a little jet engine, but boy if ain't effective.
Old Mar 20, 2019 | 05:25 PM
STRMLNE's Avatar
STRMLNE
Cooling fans louder than exhaust? 😳
Old Mar 20, 2019 | 05:38 PM
gimp's Avatar
gimp
At hot idle (which is what, like 650 rpm?), with Borla Type S catback (and catted long tubes), yes. From the rear of the car you hear the exhaust, from the front the fans, and from the side the fans I think are a little bit louder.
Old Mar 20, 2019 | 05:47 PM
STRMLNE's Avatar
STRMLNE
Wowza. Your car must never get above 100°F.
Old Mar 20, 2019 | 06:53 PM
gimp's Avatar
gimp
Ha! In fact, the coolant temp rises steadily to about 190F and then stays there. Hot california days, 190F. Mountains, 190F. Even on the track, the highest I have seen thus far is 194F. Granted, that was during 70F ambient, not, like, 110F ambient, so we'll see how it do. The dewitts rad & fan combo is lethal!
My oil does need an oil cooler, though. With the current setup and with more skill behind the wheel, summer track days would likely see around ~280-300F temps, which for some people is okay but not for me. Currently not beating on it too hard and driving in cooler weather, I get up to about 245F oil, so I know the cooler is needed.
One of the lessons I've learned is that superchargers are really not worth it for track use unless you're really committed to upgrading everything to handle the power, speed, and heat. Life is way easier with an NA setup - even a fairly wild NA setup - than an FI setup. GM spent about 200 pounds to make their FI setup work on the track, and GM is doing real engineering for a much lower unit cost than it takes in the aftermarket.
Pounder's Avatar
Pounder
1/4 mile/AutoX
taking the center sway bar mounts off and letting the sway bar drop down, makes the fan removal very easy !!!!
Old Mar 21, 2019 | 05:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just remove the fan shroud assy and inspect the fans. Yes, you can lube up the motor bushings. It will give them more life and save cash..
Old Mar 21, 2019 | 06:31 PM
My Vette Life's Avatar
My Vette Life
I have my fans out, which part you suggest to lube?
Old Mar 21, 2019 | 09:51 PM
STRMLNE's Avatar
STRMLNE
what do you recommend as lube? Wd40?
Old Mar 22, 2019 | 12:12 AM
gimp's Avatar
gimp
WD40 is not lubricant. I'm not entirely sure what's squeaking. As a general rule, rubber will take kindly to silicone lubricant, moly grease, and/or marine grease.
Old Mar 22, 2019 | 12:41 AM
STRMLNE's Avatar
STRMLNE
the rad fans are squeaking
To Rad Fans
